Vegas Pro Production Assistant 2 Batch processing .veg files
COW Forums : VEGAS Pro
Areal Nayme
on Aug 18, 2016 at 11:03:23 pm
Just got Vegas Pro Production Assistant 2 and think maybe I misunderstood some advice someone gave me to buy this. I want it to batch render a folder of completed videos that now sit in the form of Sony Vegas 13 .veg files. Instead of me pushing render every hour or so to do so myself, it, I was told, would just process one after another. But, I'm not seeing how it does this....
How does it do this?
John Rofrano
Re: Vegas Pro Production Assistant 2 Batch processing .veg files
on Aug 19, 2016 at 9:40:12 pm
[Areal Nayme] "I was told, would just process one after another. But, I'm not seeing how it does this...."
  1. On the Source Media tab, Add all of your veg files to the list
  2. On the Processing tab, Select (none) as the preset and set Options to: Process each file individually. It's important that you set this correctly or else it will not process each file in succession.
  3. On the Target Outout tab, Select your Output location and Output formats
  4. Press Process
Production Assistant will process each veg file individually by rendering to all of the output formats you selected.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
