Vegas Pro 13 keeps crashing when stabilizing 4K video
COW Forums : VEGAS Pro
Linus Petraitis
on Aug 17, 2016 at 6:27:31 am
Does anyone experience something like that? I get a crash like every 2 or 3 clips. I can't edit 4K videos. What the hell?
Problem Description
Application Name: Vegas Pro
Application Version: Version 13.0 (Build 453) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:Program FilesSonyVegas Pro 13.0proDADMercalli20.dll
Fault Address: 0x00007FFD64CA6B36
Fault Offset: 0x0000000000046B36
Fault Process Details
Process Path: C:Program FilesSonyVegas Pro 13.0vegas130.exe
Process Version: Version 13.0 (Build 453) 64-bit
Process Description: Vegas Pro
Process Image Date: 2015-06-05 (Fri Jun 05) 13:53:04
Guðmundur Sigmundsson
Re: Vegas Pro 13 keeps crashing when stabilizing 4K video
on Aug 23, 2016 at 11:56:48 am
I´ve been experiencing the same behaviour.
It is really unstable but to mee it seemt like it always occurs on the same files. Meaning that if it works on some file I can repeat that multiple times without it crashing. Similary if it fails I can be sure it is going to fail everytime I try again.
Ryan Gray
on Sep 25, 2017 at 10:05:29 pm
I'm having the same issue. Have either of you experienced any kind of resolution or workaround yet?
