Recommended Monitor
COW Forums : VEGAS Pro
Ron Whitaker
Recommended Monitor
on Aug 13, 2016 at 11:56:21 pm
Does anyone have a good monitor to recommend for video editing using Vegas?
I believe John Rofrano some time ago recommended an Asus.
I'd like something in the 21" - 24" size range.
Thank you.
John Rofrano
Re: Recommended Monitor
on Aug 14, 2016 at 1:39:33 pm
[Ron Whitaker] "I believe John Rofrano some time ago recommended an Asus."
My two ASUS ProArt PA246Q's are still going strong. I didn't sell them with my 6-Core PC and I use them now as the primary monitor on my 2008 Mac Pro 8-Core and the secondary monitor my 2010 Mac Pro 12-Core. They are both 5 years old now and I've had no issues at all. I can highly recommend them. Obviously they don't make this model after 5 years but whatever they replaced it with should be great.
They came pre-calibrated from the factory and shipped with a printout of the calibration report. I keep them calibrated with my Spyder 5 Pro but they were set up accurately from the factory. I've been very happy with them.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Ron Whitaker
on Aug 14, 2016 at 2:20:44 pm
Thank you.
Wayne Waag
on Aug 15, 2016 at 1:40:14 am
I use a couple of 24" Dell U2412M IPS monitors. I've had them for about 4 years now and they are still available, although about $100 less now--$260 at B&H.
https://www.bhphotovideo.com/bnh/controller/home?O=&sku=829236&gclid=CKvl-q...
They were pretty spot-on accurate upon delivery. I've calibrated them since using a Spyder colorimeter, but afterward could see no difference. They're 1900 x 1200 with analog, dvi, and display port outputs--no HDMI. They also have USB ports which can be pretty handy. I believe Dell sells newer versions. All in all I've been very pleased.
You might consider a UHD display, although at the moment Vegas 13 does not work very well and some have had to revert back to using 1920 x 1080 which kinda defeats the purpose of UHD. Hopefully, those issues will be addressed in the upcoming version of Vegas from Magix.
wwaag
David Shirey
on Aug 15, 2016 at 4:41:42 pm
Although I never buy Dell computers, I've been a fan of their monitors for a while, especially since IPS came out. Still have my 24" but if I do switch to a larger 1440p in the future I'll probably go with Dell again.
Ron Carlton
on Aug 16, 2016 at 2:01:09 am
Sony Vegas Pro 13 does not play well with a 4K monitor, if you decide to go that route. Tool buttons are extremely small, almost unusable.
David Shirey
on Aug 16, 2016 at 8:12:01 pm
Ron makes a good point that there's really no benefit to more pixels if you're happy with how things look at the size monitor you have. I like how 1920x1200 looks at 24" so I'd only go 1440p if I were moving to maybe a 26", and I wouldn't think of 4k unless I was going at least 30", which would require me clearing all these ancient DVD/Blu-Ray copy towers off my desk.
Nigel O'Neill
on Aug 16, 2016 at 12:31:25 pm
I am currently looking at a 27" Benq SW2700PT IPS Adobe RGB Color Management Monitor. It's a bit pricey, but rated as a reasonable monitor for photo and video editing
My system specs: Intel i7 970, GTX570, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
