Hitfilm 4 with Vegas Pro 13
COW Forums : VEGAS Pro
Ron Whitaker
on Aug 12, 2016 at 11:50:07 pm
I have Vegas Pro 13 and just downloaded the Hitfilm 4 Pro demo to test out.
But when I go into Vegas, right-click on a clip in the timeline, there is no option in the menu (as there should be) to edit in Hitfilm.
I think it's a problem with Vegas, isn't it? Is there a work around to get it to work?
Marco Baer
Re: Hitfilm 4 with Vegas Pro 13
on Aug 13, 2016 at 9:55:19 am
Yes, there is, but it's a bit complicated:
- Install HitFilm Ultimate (2) and activate it (you can use the demo version which is still available).
- Rename program folder (e.g. "HF2U")
- Copy program folder "HF Pro 4" and rename the copy to "HitFilm 2 Ultimate"
- From the program folder "HF2U" copy (overwrite) the file "HitFilmFileIOPlugin.dll" to the program folder "HitFilm 2 Ultimate".
- In program folder "HitFilm 2 Ultimate" (which should be the copy of "HF Pro 4") rename the .exe file to "HitFilmUltimate.exe".
- Be sure in the Vegas Pro program folder the file "HitFilm 2 Ultimate.fio2007-config" exists and it contains the correct path (to "HitFilm 2 Ultimate").
Once these modifications are done the workflow of using HitFilm Pro 4 from within Vegas Pro 13 should work the usual way (at least it does for me).
Marco Baer
on Aug 22, 2016 at 6:18:39 pm
Did this work for you?
