How to transistion a left to right before and after grading sliding across the screen.
COW Forums : VEGAS Pro
Derek Charles
on Jul 29, 2016 at 10:04:51 am
An exact example would be in the intro to this video - I want to show before and after color grading but have it slide like this. Thanks!
Graham Bernard
Re: How to transistion a left to right before and after grading sliding across the screen.
on Jul 29, 2016 at 10:33:38 am
Easy.
In PAN/CROP use an Animated Mask and have the Mask "Apply to FX" set to YES.
Takes about 2 mins to setup.
* Grazie
Edward Troxel
on Aug 6, 2016 at 5:14:03 pm
Or, have the event without an effect and then overlap with the event with the effect and change the transition to a wipe.
Edward Troxel
Derek Charles
on Aug 17, 2016 at 9:38:26 am
I must admit, I am still very confused on what to do.
Graham Bernard
on Aug 17, 2016 at 10:23:57 am
[Derek Charles] " I am still very confused on what to do."
Understood. If it should help I've attached my approach to this. Just ADD as a Take any of your media and you will see the Black and White SONY Fx will scan across.
Here's the result:
Here's the VEG file for you
10424_movingfx1a.veg.zip
* Grazie
