Problem with Gaussian Blur effect in vegas pro 13.0
COW Forums : VEGAS Pro
Ahmed Mohamed
on Jul 27, 2016 at 4:10:58 pm
Hello everyone, I hope you are all feeling great!
Basically I want to create a 16:9 video using 4:3 clips. To fill the black bars on the sides without stretching the picture, I decided to create a zoomed in, blurred background using the clips I have and place the same clips with their original size/aspect ration on top of it. So it should look something like this: http://i.imgur.com/PP6ngz7.jpg
When I apply the Gaussian blur on the background event, everything looks fine. However, when I try to place an event on top of it, the blurred background starts to act weirdly (like it displays random frames and sometimes freezes on couple of frames). And it only happens when there is an even on top of it. When I remove the upper event, to goes back to normal.
Below short samples that show what I mean:
- Background only: https://goo.gl/ovv75b
- Event on top of background: https://goo.gl/Km2woZ
I can't seem to find the source of the problem and I hope someone has an answer :)
Steve Rhoden
Re: Problem with Gaussian Blur effect in vegas pro 13.0
on Jul 27, 2016 at 4:59:40 pm
Sounds like that is a GPU related issue. Try disabling the GPU and then see if it still happens.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Wayne Waag
on Jul 27, 2016 at 5:44:40 pm
Steve's probably right about the GPU. I've done something similar except rather than using blur, I've used the levels FX and simply moved the black levels up to around 50%. Looks roughly the same and renders a lot faster.
wwaag
Ahmed Mohamed
on Jul 27, 2016 at 6:02:58 pm
He is. I disabled GPU acceleration and it works now.
Also thanks for sharing your experience.
Ahmed Mohamed
on Jul 27, 2016 at 6:00:24 pm
Thank you so much Mr. Rhoden, that solved the problem.
I am very grateful to you :)
Steve Rhoden
on Jul 28, 2016 at 3:54:18 am
You are most welcome Ahmed....
Happy editing!
