Which of these crap video cards will be better. Hehehe...
COW Forums : VEGAS Pro
Joshua Jackson
on Jul 12, 2016 at 11:32:43 pm
Hello...
I'm building a new editing computer.
I'll have the Intel i7-6700 (not K) and so it will have some on-board video ability.
My understanding is that the new core CPUs actually have decent hardware acceleration.
My intention is to get a Radeon RX 480, but they are sold out.
In my possession are as follows...
Intel i7-6700 (Intel HD Graphics 530)
GPU Clock: 300 MHz
Boost Clock: 1050 MHz
Memory Clock: System Shared
Memory Size: System Shared
Memory Type: System Shared
Memory Bus: System Shared
Bandwidth: System Dependent
Shading Units: 192
TMUs: 24
ROPs: 3
Pixel Rate: 900 MPixel/s
Texture Rate: 7.20 GTexel/s
Floating-point performance: 115.20 GFLOPS
Radeon x1950 Crossfire Edition
GPU Clock: 650 MHz
Memory Clock: 1000 MHz / 2000 MHz effective
Memory Size: 512 MB
Memory Type: GDDR4
Memory Bus: 256 bit
Bandwidth: 64.0 GB/s
Pixel Shaders: 48
Vertex Shaders: 8
TMUs: 16
ROPs: 16
Pixel Rate: 10.40 GPixel/s
Vertex Rate: 1.300 GVertices/s
Texture Rate: 10.40 GTexel/s
Radeon HD 2400 Pro
GPU Clock: 525 MHz
Memory Clock: 400 MHz / 800 MHz effective
Memory Size: 256 MB
Memory Type: DDR2
Memory Bus: 64 bit
Bandwidth: 6.40 GB/s
Shading Units: 40
TMUs: 4
ROPs: 4
Compute Units: 2
Pixel Rate: 2.100 GPixel/s
Texture Rate: 2.100 GTexel/s
Floating-point performance: 42.00 GFLOPS
Radeon HD 3450
GPU Clock: 600 MHz
Memory Clock: 500 MHz / 1000 MHz effective
Memory Size: 256 MB
Memory Type: DDR2
Memory Bus: 64 bit
Bandwidth: 8.00 GB/s
Shading Units: 40
TMUs: 4
ROPs: 4
Compute Units: 2
Pixel Rate: 2.400 GPixel/s
Texture Rate: 2.400 GTexel/s
Floating-point performance: 48.00 GFLOPS
I'm going to assume that the on-board video will be the best (just judging by the GFLOPS numbers).
Does that seem like the logical choice?
JJ
John Rofrano
Re: Which of these crap video cards will be better. Hehehe...
on Jul 13, 2016 at 1:14:55 pm
[Joshua Jackson] "I'm going to assume that the on-board video will be the best (just judging by the GFLOPS numbers)."
You guessed correctly. Those video cards are absolutely anemic by today's standard. It's not even woth wasting a slot on one of them.
Vegas Pro's minimum requirement is for a GPU with 512MB memory so the Radeon HD 2400 Pro and Radeon HD 3450 don't even meet minimum requirements (i.e., they are useless and won't be recognized).
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Aaron Star
on Jul 13, 2016 at 6:45:53 pm
Just use the onboard GPU if you are waiting on a 480. The RX480 is great on power usage, but not the top in calc speeds. If you want to just stick in a temp card to enable OpenCL/GPU benefits, there is always ebay. I would recommend the following in order:
AMD:
5770 (1360 gflops)
r9-270x
6970
7970-ghz
RX480
r9-290x
R9-390x
R9-FuryX (8600 gflops)
The i7-6700 is around 113 gflops, so if you do any blurs or other GPU effects adding a GPU will help even a modern CPU. If you are planning on running a 4K monitor, then use the onboard GPU, and the add on GPU for compute only. 7970 and above are the only cards to support 4k. There is a difference between display resolution ability and computational performance.
