Sapphire shake render issue
COW Forums : VEGAS Pro
Jimmy Carter
on Jul 10, 2016 at 5:26:29 am
I am using Sony Vegas Pro 13 with sapphire plugin. When I use s_shake on a clip in the preview it works just fine but when I render out the video, halfway through the clip it freezes but still shakes. Anyway I can fix this
Graham Bernard
Re: Sapphire shake render issue
on Jul 10, 2016 at 10:21:53 am
More info needed:
Project Settings.
The Media Info.
Render Template.
* Grazie
Jimmy Carter
on Jul 10, 2016 at 10:02:15 pm
Project settings 1920 by 1080 60fps
Clips 60 fps .avi motion jpeg
Lenovo
Windows 7
Gtx 750 Ti
Intel core i5
12 GB ram
Colin WuzheRE
on Jul 11, 2016 at 12:15:14 am
I'm also having issues with Sapphire.. I center zoom blur with BlurMoCurves but when i render the video it does not center the blur..
Elle Ledford
on Sep 18, 2017 at 1:20:13 pm
I was having the same issue a while back. I found that disabling GPU acceleration worked and making sure your render settings matched your project! If that doesn't help, then it would most likely be a problem with your processor being too low to support SVP.
– Elle, Sony Vegas User
John Davidson
on Jan 24, 2017 at 4:53:42 pm
I know this is an old post but i also use s_shake and it also freezes ☹
It's so annoying and i cant find a fix anywhere ☹
OS: Windows 10
intel i7 4770k
nvidia GTX 1070
32Gb DDR3 Ram
Graham Bernard
on Jan 25, 2017 at 4:48:08 am
Hi John. You certainly have enough muscle in your rig. Have you tried disabling GPU acceleration? What Preview quality are you running? Does your Project Settings exactly match your Event Media? Have you got any other VFX applied?
Bottom line, I can use Saphire Edge Shake with no issue. Let's see if we can nail this irksome critter.
* Grazie
John Davidson
on Jan 25, 2017 at 9:35:52 am
I've disabled GPU acceleration but it still freezes.. My preview quality is set to Best and my project settings match with event media. I render in MainConcept AVC/AAC. No other VFX's are applied. I think it could just be because my footage is in 60 frames per second at 1080p.
Oisin Fogarty
on Jun 29, 2017 at 5:47:16 am
hi, this is happening to me but its happening with the glow this is so annoying and i want it fixed i need this edit out
Richard Dobell
on Aug 28, 2017 at 9:31:02 pm
Hi, you might have already found a solution but just in case anybody else is struggling like I was... this is caused by your project settings not matching your rendering settings. I found that I was rendering my video in 1080p 60 fps but project settings were 1080p 25fps. I changed this and set 60fps to default, restarted the program and problem solved. Hope this helps
