How to keep anchor points the same
COW Forums : VEGAS Pro
Melody Kang
on Jun 16, 2016 at 10:33:21 pm
I'm masking animation and was wondering what to do if there are two of the same frame (the picture) and I already masked one. How do I duplicate the same points?
Russ Froze
Re: How to keep anchor points the same
on Jun 17, 2016 at 2:22:37 am
If I understand the question correctly, a simple copy and paste should do the trick. Just select the key frames that need to be copied using alt or shift for multiple selections. Then use Ctrl + c to copy move to where they are desired and use Ctrl + V to paste.
Russ Froze
