How do you install Cineform go pro in Vegas 12?
COW Forums : VEGAS Pro
Philippe Orlando
on Jun 15, 2016 at 4:51:15 pm
Hello,
I'd like to try to edit in the Cineform go pro codec in Vegas 12, but I'm not sure how to install it?
Any help appreciated.
Philippe
George Dean
Re: How do you install Cineform go pro in Vegas 12?
on Jun 15, 2016 at 5:45:07 pm
Hi Philippe,
Close down Vegas Pro. Install GoPro Studio software. Start up Vegas Pro, the CineForm codec will be in the Video for Windows (*.avi) format. Use customize template, and select the 'CineForm Codec' from the available codec options in 'Video Format:'. There is also an active 'Configure' option setting for CineForm.
Best Regards......George
Philippe Orlando
on Jun 15, 2016 at 5:53:20 pm
George,
Great, it worked. It's actually called Cineform Codec, not Cineform Go Pro Codec, I assume it's the one?
Thanks again
Philippe
George Dean
on Jun 15, 2016 at 9:09:58 pm
Hi Philippe,
Glad you got it going. Yes, it is called CineForm Codec, which is owned by GoPro and comes with the free GoPro Studio application.
I normally use it to render intermediates from ProRes/DNxHD source files. I used the YUV 4:2:2 Filmscan 1 quality, although often 'High' quality would be plenty good enough.
Philippe Orlando
on Jun 16, 2016 at 1:02:45 am
Thanks, George!
