Multiple transitions on a single clip at the same time point
COW Forums : VEGAS Pro
Navid Karim
on Apr 14, 2016 at 2:33:03 pm
So I tired to add a fade in effect with the slide in transition effect on a text clip. But I wanted the two transitions to occur at the same time like during the time the text is sliding it also fades in slowly.Any body know how I can do tht or if its even possible?
I am using Sony Vegas pro 12
( ͡° ͜ʖ ͡°)
John Rofrano
Re: Multiple transitions on a single clip at the same time point
on Apr 14, 2016 at 11:23:43 pm
It's not possible to add two transitions at the same time but if you want one of them to be a fade, then add an Opacity Envelope and use that to fade the slide transition in.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
