Something is wrong with the track
COW Forums : VEGAS Pro
Cheyenne Johnson
on Feb 21, 2016 at 4:16:17 am
http://prnt.sc/a5zjtd
I don't want it to be like that, i want it to be like the way you get it when you first get sony vegas.
Mike Kujbida
Re: Something is wrong with the track
on Feb 21, 2016 at 10:01:41 am
That's called the "expanded edit mode".
To exit expanded edit mode and return to the previous window layout; perform any of the following actions:
* Choose Edit > Select > Exit Expanded Edit Mode.
* Press 5 on the numeric keypad.
* Double-click the event edge.
* Press Esc.
Jorma Nippala
on Feb 21, 2016 at 11:38:09 am
Or you have Expanded track layers.
If you do not see any red bracket to indicate an event edge and the tricks above do not work, try right-clicking the track header and deselect Expand Track Layers. And double-clicking the vertical scroll bar will mimimize/restore the track heights.
