new to Sony Vegas - color corrector/video events fx window missing!
COW Forums : VEGAS Pro
Amorhys Fenton
on Dec 26, 2015 at 10:51:56 am
I am new to Sony Vegas (v.Pro13) and learning about the events fx feature. I have some how lost the Video FX control window.
I have tried re-setting the windows default layouts and then selecting the "color corrector (secondary)\boost mids" option. The "color wheels" window remains illusive which is most perplexing.
Any thoughts please wise members of this fine forum?
John Rofrano
Re: new to Sony Vegas - color corrector/video events fx window missing!
on Dec 26, 2015 at 12:58:08 pm
Can you upload a screen shot of what you are seeing? It would be difficult to help without seeing what you are seeing.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Amorhys Fenton
on Dec 27, 2015 at 1:50:51 am
Thank you for prompt reply John, much appreciated. Here's the screenshot to help illustrate my first post.
John Rofrano
on Dec 27, 2015 at 2:06:50 am
That window with the question mark is the Trimmer window. To display video in it, right-click your video event and select Open in Trimmer. This has nothing to do with Video FX however. It's for trimming your source before adding it to the timeline.
~jr
Amorhys Fenton
on Dec 27, 2015 at 2:18:43 am
Thanks John, I am trying to find the color corrector wheels window.
It looks like this:
https://www.bing.com/images/search?q=youtube+sony+vegas+color+corrector+win...
I thought it would be near the Trimmer window.
Jorma Nippala
on Dec 27, 2015 at 10:58:01 am
There are several methods available for adding effects to video.
You can e.g. drag a preset thumbnail to a track, event, or to the Video Preview window to apply the effect.
Drag the thumbnail to an event on the timeline to see the Video Event FX window.
Or click the Event FX button on a timeline event to add effects to the event or edit event effects.
Double-click the title bar of the Video FX window to resize it for the current plug-in.
Amorhys Fenton
on Dec 30, 2015 at 9:22:34 am
Thanks Jorma
John Rofrano
on Dec 27, 2015 at 1:31:04 pm
[Amorhys Fenton] "I am trying to find the color corrector wheels window. "
If you haven't applied the Color Corrector yet, you can simply drag and drop one of the presets that you already have in the FX tab to your video and the FX window will open starting with that preset as seen in the image below (1).
If you already applied the color corrector and just want to get back to the FX window, press the Green FX button on the event that you applied it to as designated in the image above (2) and the FX Window will open back up.
~jr
Amorhys Fenton
on Dec 30, 2015 at 10:00:47 am
Thank you John, that's helping me. I followed your steps however the Color Correction window and the Color wheels still does not appear. It's odd as it used to load up. I have edited your nice steps and added the missing window, highlighted with the green question mark.
I've also tried using Sony Vegas on my big screen (1280 x 800 resolution). Could it be as I am only running the trial version?
John Rofrano
on Dec 30, 2015 at 4:33:45 pm
What do you see when you press the green FX button? If the FX window does show up. Close Vegas Pro, hold down the Shift+Ctrl keys while opening Vegas Pro again. This will prompt you to reset all of your preferences. Reply Yes and see if that resets the window positions.
~jr
Amorhys Fenton
on Jan 1, 2016 at 10:43:26 am
Yes thanks John, that fixed it. A thousand thanks for your patience and assistance.
John Rofrano
on Jan 1, 2016 at 3:22:46 pm
You're welcome Amorhys. Glad that helped!
~jr
Edward Troxel
on Dec 27, 2015 at 8:06:34 pm
It could have been moved "off the screen". You might try changing to a higher video resolution and then locate the window and move it back to the main area. Then you can reset it to the resolution you desire.
Edward Troxel
Amorhys Fenton
on Dec 30, 2015 at 9:26:26 am
Thanks Edward, I will try that too.
Jorma Nippala
on Dec 30, 2015 at 11:21:45 am
If other methods fail, try resetting back to factory defaults (including all preferences you have changed).
"Close the program. Now press CTRL+SHIFT while double-clicking on the program's icon to launch it. Continue to hold the CTRL & SHIFT keys until the program is fully up and loaded.
In newer programs, you will see a window that asks "Do you want to reset all preferences to default values?" Place a checkmark next to "Delete all cached application data" and then click Yes.
Amorhys Fenton
on Jan 1, 2016 at 10:50:23 am
Many thanks Jorma. That worked perfectly. Interesting how the settings and cache go awry.
