Adding label to track ?
COW Forums : VEGAS Pro
Rick Hughes
on Nov 6, 2015 at 2:00:14 pm
Using Sony Movie Studio 12
On a video I may add several individual pieces of music on a single track ..(as apart to separate audio tracks)
As there may be a number of files in the 'project media' window it can sometimes get difficult to know which I have used.
Is there a way to add a label onto a track .. i.e. give it a name.
As an example ... could have a 15 min video track and I have 5 separate mp3 files .... as I put all these on the same audio track ... easier to visualise envelopes, fade in etc. Be good to be able to apply a label to each of the files where they appear in the timeline.
Seems so obvious I guessing you can, would assume if you right click and event you could add a name - but not so ,,, can it be done ?
Or even add automatically the name from the media file if that is an option.
I know if I used separate tracks I can name each track.
Mike Kujbida
Re: Adding label to track ?
on Nov 6, 2015 at 2:04:27 pm
View - Active Take Information.
Ctrl + shift + I is the keyboard shortcut.
This is in Vegas Pro so I'm not sure if you have it in Movie Studio. It's worth a try :)
George Dean
on Nov 6, 2015 at 2:59:41 pm
It's exactly the same in Movie Studio 13.
Best Regards.....George
Rick Hughes
on Nov 6, 2015 at 4:05:12 pm
Yes it is .... thought it was so obvious a function.
Mike Kujbida
on Nov 6, 2015 at 8:37:59 pm
So was that a solution for you?
Rick Hughes
on Nov 6, 2015 at 9:02:16 pm
Mike ... when I replied "Yes it is .... thought it was so obvious a function."
I meant that in repose to your answer ... seems to have arrived out of sequence ... it worked Thank you
Mike Kujbida
on Nov 6, 2015 at 9:20:41 pm
Rick, I'm glad to hear that it worked for you. I have it enabled all the time.
Peyton Todd
on Jun 12, 2017 at 6:24:23 pm
Yes, but how do you turn on the labels that usually (in my case) appear to the left of each track - the ones where you can mute a give track, for example? I never want these to go away, but sometimes they do... I suppose I must have inadvertently pressed some keystroke combination.
David Eon
on Jul 15, 2017 at 8:50:00 am
A quick way to match up events on your timeline to the files in the media manager is to select the events you want, then right click>Select in Project Media list. It will highlight all of the source media files that you have selected on your timeline. I hope that helps. Thanks!
DavidEon
