Using camcorder pass-through vs. ADVC device for Sony Vegas capture/external preview
COW Forums : VEGAS Pro
Rick Anvican
on Jul 17, 2015 at 11:52:56 pm
Hi all,
I have been offered a functional Sony DSR-PD150 and would like to use it as a DV pass-through device for capturing from and outputting to analog devices. Is anybody still using pass-through on a camcorder and would like to comment on the signal quality when compared to a dedicated capture device like the Canopus ADVC devices? Thanks in advance.
John Rofrano
Re: Using camcorder pass-through vs. ADVC device for Sony Vegas capture/external preview
on Jul 18, 2015 at 6:28:21 pm
[Rick Anvican] "Is anybody still using pass-through on a camcorder and would like to comment on the signal quality when compared to a dedicated capture device like the Canopus ADVC devices? "
It should be just as good as the ADVC-100 but not as good as the ADVC-300 with TBC. If you weren't going to spend the money for the ADVC-300 or you don't need Time Base Correction, then go for it. It should work great.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Rick Anvican
on Jul 18, 2015 at 10:46:49 pm
[John Rofrano] "It should be just as good as the ADVC-100 but not as good as the ADVC-300 with TBC. If you weren't going to spend the money for the ADVC-300 or you don't need Time Base Correction, then go for it. It should work great."
Thanks John, I did expect that camcorder DV pass-through would perform a bit under the ADVC devices but I do hope that the camera being a 3CCD model, the quality of its converter should be good.
John Rofrano
on Jul 19, 2015 at 4:12:10 pm
You're welcome. Lots of people use a DV cameras pass thru for analog conversions so you should be fine.
~jr
