How do I freeze markers on the timeline?
COW Forums : VEGAS Pro
Jeff David
on Jul 8, 2015 at 7:41:28 pm
I tried looking in the help section, didn't find anything.
I did a search of the forums, but didn't find the right answer.
I don't want to spend hours trying to figure it out so can anyone please tell me, how do you freeze the markers on the timeline.
I am sure you all know what I mean but just in case,
I set up markers.
Now, I am still editing and so I am moving clips on the timeline, but the marker does not move w them so once you move some of the clips around the markers are rendered useless and all over in the wrong places?
Thanks in advance for any help
Lenovo quad core i7 16gb of ram, Windows 8.1 MS 13 64 bit
John Rofrano
Re: How do I freeze markers on the timeline?
on Jul 9, 2015 at 11:34:28 am
[Jeff David] "Now, I am still editing and so I am moving clips on the timeline, but the marker does not move w them so once you move some of the clips around the markers are rendered useless and all over in the wrong places?"
That's because the Markers are connected to the Timeline and have no relation to any of the clips on any of the tracks. They mark timeline positions. You can use Ripple Edit and set it up to have a marker move with Events if you want but use this carefully as it can really mess things up.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Jeff David
on Jul 10, 2015 at 5:10:20 pm
OH I see.
Ok fixes them to the timeline. I did not make that connection but now I see. Ahhhh!
OK thanks for the warning. IF there is a chance of really messing up then I won't fix the markers.
I'm doing ok just moving them back now - but I don't have too many so it's ok but if I had a lot of markers, couldn't do that.
But I only need a few of them at this point.
thanks again!
John Rofrano
on Jul 10, 2015 at 10:04:43 pm
[Jeff David] "OK thanks for the warning. IF there is a chance of really messing up then I won't fix the markers."
Try experimenting with Ripple Edit. I didn't mean for you to be afraid of using it, I just want you to be aware that you should turn it on when you need it and turn it off when you don't.
~jr
