Random crashing?
COW Forums : VEGAS Pro
Ben Albright
Random crashing?
on Jun 20, 2015 at 12:41:01 am
As I've continued making videos in Vegas, I get more frequent crashes each time. With my first and second video, I hardly had any crashes. But lately Vegas has crashed every 5 minutes. What could be causing this?
John Rofrano
Re: Random crashing?
on Jun 21, 2015 at 3:45:14 pm
It could be the version of Vegas Pro that you are using, or a conflict with some other software installed on your OS, or the media that you are using, but without knowing anything about any of these things it's really hard for anyone to say what might be causing it. Why don't you tell us more about what software you are using and what you are doing with it before it crashes and see if anyone has an ideas.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Ben Albright
on Jun 21, 2015 at 4:35:28 pm
I am using Vegas Pro 13. All media is in the same folder, and don't know of any other software that might be messing with it. I'm editing the video like anybody would, dragging events on the timeline, adding new media. But even without editing anything, even so much as PLAYING the preview makes it crash.
It simply says "Vegas Pro 13 is not responding."
John Rofrano
on Jun 21, 2015 at 5:47:10 pm
[Ben Albright] "I am using Vegas Pro 13."
Make sure that you are using the latest build 453.
[Ben Albright] "I'm editing the video like anybody would, dragging events on the timeline, adding new media"
Where did the media come from? (Camera, Internet, Screen Capture?)
What format are the media files? (AVI, MP4, MOV?)
What codec does it use? (DixV, Xvid, H.264, M-JPEG, MPG?)
There is a free utility called MediaInfo that can give you this information if you don't already know it.
~jr
Ben Albright
on Jun 21, 2015 at 6:14:59 pm
The media is screen-captured footage. It's one video, AVI format, using the Xvid codec. The rest of the media files are MP3s, of which there are about 20.
John Rofrano
on Jun 22, 2015 at 10:46:59 am
[Ben Albright] "...using the Xvid codec."
That's your problem. Vegas Pro does not work well with Xvid. You need to transcode that video into a format that Vegas can edit. Try converting it to M-JPEG with PCM audio using AviDemux 2.5 (don't use 2.6, only 2.5 work with Vegas Pro)
~jr
Ben Albright
on Jun 22, 2015 at 6:11:07 pm
Actually, I figured out the actual problem. My GPU was accelerating video processing. Once I turned it off, no more crashes. Thanks for your help, though.
John Rofrano
on Jun 22, 2015 at 6:59:09 pm
I would do a test render and make sure that it looks OK. I have seen renders contain scrambled frames when Xvid was the source.
~jr
