Video format Q
COW Forums : VEGAS Pro
Rick Hughes
Video format Q
on May 13, 2015 at 7:09:26 pm
Probably a simple one ... but realised I don't know the answer.
Sony Move Studio 12
If I click on one of my video clips in the Project Media window ... at the bottom of the window it gives the file data .. For example:
Video: 1920x1080x12, 59.940 fps etc.
Now I know what 1920 x 1080 is, and I know what fps is ... but what does the '12' stand for ?
John Rofrano
Re: Video format Q
on May 14, 2015 at 12:47:03 am
[Rick Hughes] ".. but what does the '12' stand for ?"
It's the number of bits per pixel at an 8 bit color depth. In your case 12 bits per pixel (8 bit YUV with 4:2:0 chroma subsampling, a.k.a. YV12). YUV 4:4:4 would be 24bit, 4:2:2 is 16bit, and 4:2:0 is 12bit per pixel.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Rick Hughes
Re: Video format Q
on May 14, 2015 at 12:58:51 pm
Is this normally 'set' by the recording device (i.e camera) and not something I could/should set somewhere in Vegas.
For example my camera I can set video frame size and framerate but see no setting for bit depth?
I leave this set at 1920 x 1080, 60 fps
Just happened to notice the '12'
John Rofrano
Re: Video format Q
on May 14, 2015 at 7:20:42 pm
[Rick Hughes] "Is this normally 'set' by the recording device (i.e camera) and not something I could/should set somewhere in Vegas."
That's correct. Vegas Pro is just showing you the details of the video that you already shot. All internal processing in Vegas Pro is 4:4:4.
~jr
