New to Vegas, need assistance with
COW Forums : VEGAS Pro
Aldo Barani
on Apr 6, 2015 at 9:48:51 pm
joining tracks. Have used Corel Pinnacle Studio before (no expert though) and I use a copy of Vegas Pro 13 now.
The problem I'm facing is this: when joining 2 or more video tracks, after the transition from track 1 to 2 (for example) the 2nd track displays briefly a still image from the end of the track before switching to the normal motion picture. Track 1 always run fine.
What should I do to remove or avoid that? And how?
Thank you.
AB
JF Baez
Re: New to Vegas, need assistance with
on Apr 7, 2015 at 8:30:23 am
Hello there, I am not an expert but I think you should tell us what video format you are using, since, In my opinion, my guess is that you could have a video format issue.
are both clips the same format?
Hope to see this solved.
Aldo Barani
on Apr 7, 2015 at 12:52:40 pm
Sorry for missing that; the videos I'm trying to join are MP4 and where shot with a Sony Action Cam, therefore should work with the Vegas that is also a Sony product.
JF Baez
on Apr 7, 2015 at 9:35:06 pm
Ok I see your point, have you test it with different clips?
is always the same result?
if you render the project, is the output doing the same?
Aldo Barani
on Apr 8, 2015 at 10:57:21 pm
I found the cause, it was because of the transition I have inserted between tracks.
JF Baez
on Apr 9, 2015 at 4:10:08 am
hahahahah good!! glad to know, cheers!
