Animating FX?
COW Forums : VEGAS Pro
Pat Adams
Animating FX?
on Mar 14, 2015 at 6:31:04 pm
For example, I want to change a single clip from, i.e, colour to B/W, (or from sharp to Blur etc.) but cannot figure out how to smoothly get the transition with the "Animate" button. I've looked all over the site cannot seem to find a tutorial. Can anyone point me in the right direction?
Phil Peacock
Re: Animating FX?
on Mar 15, 2015 at 11:04:47 am
If I read this correctly, all you need to do on your event window timeline (once you have enabled animation) is to create keyframe where you want the effect to commence and set the blend amount to what you want. Then move your cursor to where on the timeline you want the effect to finish, and move the blend amount slider to where you want it (probably at the opposite end of the slider to the first keyframe). You can experiment too with rightclicking the keyframe and selecting any one of the properties listed although this won't make much difference to this particular effect.
Too easy so I may have misread your issue!
Pat Adams
Re: Animating FX?
on Mar 15, 2015 at 9:34:53 pm
Ah..Thank you! That is very helpful and I think I can get the hang of it now.
