An error occurred preparing the disc + failed to connect ipc
COW Forums : VEGAS Pro
Jeff David
on Mar 14, 2015 at 12:09:15 am
I was attempting to render and burn a blu ray.
Now, I have previously successfully rendered and burned a 2 hour blu ray but this time when I tried to do it, the first attempt I got:
error preparing image
failed to connect ipc port
system can't find the file specified
I'm guessing that I lost the connection w the usb port?
I know sometimes the connection gets lost i.e. if I look in DEVICE MANAGER I will see the yellow, yield or caution icon indicating the port is not functional.
I reboot and the port functions again.
I didn't think to look in device manager but I am guessing that the error means for some reason the usb port stopped functioning?
SO I attempted a second render after shutting off all background processes via msconfig and disabled all start up items and rebooted which possibly reset the usb port - if indeed that was the cause of the first error.
Second attempt I made it appeared that I made it all the way through the render, as far as I can tell, of the 2 hour project but got the error mssg:
an error occurred preparing the disc.
I had the same un-rewritable disc in the blu ray burner both times.
I thought being as the render failed at that 28% complete point the first attempt that I could still use the same disc for the second attempt.
When going through the, "MAKE MOVIE" steps I select;
render image and burn
1920 x 1080 10mbps (the frame size showing of the footage I shot)
File path c drive (where ms 13 project is, my clips are on d drive)
Any ideas why I got the error messages?
Maybe the disc somehow got written on during the first render/burn attempt? It never made it all the way through render so I figured it was still empty.
Under properties, it shows as 100% of the space is free.
I tried attaching a screen shot in of the make movie selections using word but it said file type not supported.
Lenovo quad core i7 16gb of ram, Windows 8.1 MS 13 64 bit
Jeff David
Re: An error occurred preparing the disc + failed to connect ipc
on Mar 14, 2015 at 12:21:00 am
Correction, the frame size of the video is 1440 x 1080 and the pictures in project are 1920 x 1080
The first attempt at render/burn I selected 1920 x 1080 and the second tome
I selected 1440 x 1080.
Maybe having selected 1920 by 1080 caused the first failed attempt?
