Zooming without Pan/Crop tool
COW Forums : VEGAS Pro
Sue Donnel
on Jan 8, 2015 at 2:31:44 am
I have two images, one original on the bottom track and one masked on the top. Is there a way to zoom into the clip and have the mask still move without using pan/crop?
OR if I must use the pan/crop tool, is there a way to zoom in without messing up my moving mask?
john bolton
Re: Zooming without Pan/Crop tool
on Jan 8, 2015 at 8:25:16 am
Use the track motion. It is at the start on the time lines where the level adjustment slider is and is a small white box with an arrow in it. If you click it you can key frame where you want to adjust and just grab the edge of the box to adjust size or move.
Aleksey Tarasov
on Jan 8, 2015 at 11:33:45 am
In other words, you want to zoom-in both images simultaneously?
1) Copy Pan/Crop settings from one image to another (Paste Event Attributes)
2) Use Track Motion (two compositing childs, one parent track - use parent motion for zooming)
3) You can put your images in a separate project, add it to the main timeline, and use Pan/Crop with the nested project.
