Better tool than "Brightness and Contrast?"
COW Forums : VEGAS Pro
Pat Adams
on Dec 26, 2014 at 5:36:26 am
A few pages back, Edward Troxel mentioned there is a way to brighten/contrast without affecting every pixel of the entire clip.
Could someone point me in that direction?
John Rofrano
Re: Better tool than "Brightness and Contrast?"
on Dec 26, 2014 at 1:35:22 pm
You should be using Color Curves instead of the primitive Brightness and Contrast tool. It gives you lots more control. You can use a Mask to only affect part the frame with an effect. You can also use the Secondary Color Corrector to only affect certain colors in a frame.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Pat Adams
on Dec 26, 2014 at 5:34:29 pm
Thank you John. I have fiddled with those tools, but without much success. I'll check for a tutorial on this site.
John Rofrano
on Dec 26, 2014 at 7:13:16 pm
For Color Curves you want to start by making an 'S' and adjusting from there. You can double-click on the curve to create another point and really target what is affected but I fond that most of the time, a simple 'S' is all that's needed.
There are lots of great tutorials here on the COW for some of the others.
~jr
Pat Adams
on Dec 27, 2014 at 3:29:32 am
Off to give it a try. Thanks!
