Cant see video in pan and crop.
COW Forums : VEGAS Pro
Erik Larsson
on Dec 2, 2014 at 4:46:05 pm
I want to motion track in vegas, i figured il motion track frame by frame. but if i take my ex: image, and click pan and crop and move my pan and crop timeline, my preview doesnt move. this makes it imposible for me to motion track.
I bought vegas 13 in hope that it would fix it (i had 12 before) but no luck.
If anyone has a suggestion please let me know what i should do.
Mike Kujbida
Re: Cant see video in pan and crop.
on Dec 3, 2014 at 2:43:49 am
Enable the Sync Cursor button (it looks like a lock) at the lower left of the Pan/Crop window. Once you do this any and all changes will be show immediately in your preview window.
Be advised that any changes you make will result in a new/modified keyframe so be careful or you'll end up with unwanted ones.
John Rofrano
on Dec 8, 2014 at 11:49:59 am
As Mike said, you have to enable Sync Cursor. If you want "real" Motion Tracking check out BorisFX's Match Move plug-in from their Continuum Complete Units collection. That will give you a Motion Tracker and a Corner Pinner that you can use right inside of Vegas Pro.
Motion Tracking
Corner Pinning
~jr
http://www.johnrofrano.com
http://www.vasst.com
David Martin
on Oct 4, 2016 at 7:06:55 am
I also had this problem, but thanks to a response nearly 2 years old I have it working again. My problem was a bit different, in that I saw only a solid black rectangle where the preview image should be. Normal preview was working, and the crop tool was working, just no preview in the crop window.
Great site.
