Making transitions faster
COW Forums : VEGAS Pro
Karina Yefremova
on Nov 12, 2014 at 1:29:47 am
Hello! I just started using sony vegas, and I need assistance with how to make the transitions faster. For example i'm trying to do a push up transition between two clips however it's too slow. Thank you!
Mike Kujbida
Re: Making transitions faster
on Nov 12, 2014 at 1:44:07 am
The only way to make the transition go faster is to shorten the overlap time between the two events (what Vegas calls a clip).
Phil Peacock
on Nov 12, 2014 at 9:45:20 am
As Mike said. Just drag with the left mouse button the left or right edges of the transition to shorten the duration of the transition.
Karina Yefremova
on Nov 12, 2014 at 7:07:00 pm
Thank you very much!!! to both of you.
