adding sun rays
COW Forums : VEGAS Pro
Tobin Bell
adding sun rays
on Oct 25, 2014 at 1:32:58 pm
Hey there,
I have 2 images:
http://i.imgur.com/4uVurwC.png
and
http://upload.wikimedia.org/wikipedia/commons/d/d5/Wilhelm_Gross-4.jpg
I want to create a very short animation where the sun moves slowly in the back while the other image stands still in the front. I also need some rays on the black ground areas that follows the sun's movement, in this style:
https://images.creativecow.net/u/262538/sunshafts.jpg
Is this possible to make the rays in Vegas? If so, would you instruct me please how can I do it?
Thanks in advance!
John Rofrano
Re: adding sun rays
on Oct 26, 2014 at 10:46:57 am
[Tobin Bell] "Is this possible to make the rays in Vegas? If so, would you instruct me please how can I do it?"
Yes, use the Sony Rays plug-n.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Tobin Bell
Re: adding sun rays
on Oct 26, 2014 at 1:19:21 pm
Thanks for the tip John, I meant it's not that easy because the alpha channeled front picture messes up the ray prints. However I managed to solve this issue by adding a third image of a flat mix of the two involved image and then used the rays plugin with the "Effect only" option.
John Rofrano
Re: adding sun rays
on Oct 27, 2014 at 10:42:49 am
[Tobin Bell] "I managed to solve this issue by adding a third image of a flat mix of the two involved image and then used the rays plugin with the "Effect only" option."
That was a good solution. Sometimes you need to duplicate a track to use as a mask for other tracks. Im glad you figured it out.
~jr
