snapping and unsplit
COW Forums : VEGAS Pro
Glenn Rotar
on Mar 29, 2014 at 7:46:16 pm
Basic question
I would like to know how to unsplit a piece in my timeline (or rejoin 2 pieces of video)
2- Also the feature "snapping" seems to be somehow turned off. When I drag and touch to pieces of video it used to snap together like magnets do, but now they too easily overlap or are not joined. I would like to re-engage the snapping feature.
Thanks for your help
Glenn
John Rofrano
Re: snapping and unsplit
on Mar 30, 2014 at 12:52:15 pm
[Glenn Rotar] "I would like to know how to unsplit a piece in my timeline (or rejoin 2 pieces of video)"
Delete the right-side event and drag the edge of the left-side event to reach the same length at the right side was. You will have one long event again.
[Glenn Rotar] "Also the feature "snapping" seems to be somehow turned off. When I drag and touch to pieces of video it used to snap together like magnets do, but now they too easily overlap or are not joined. I would like to re-engage the snapping feature."
The first icon on the toolbar after Undo/Redo is Enable Snapping. Toggle it on by clicking it or use F8 to turn it on and off.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Glenn Rotar
on Mar 30, 2014 at 8:01:09 pm
Thanks John
Both of those work fine.
I thought I had read a year or so ago that press "S" to split and press "?" for an unsplit or a rejoin.
Is there such a command?
John Rofrano
on Mar 30, 2014 at 11:04:45 pm
[Glenn Rotar] "I thought I had read a year or so ago that press "S" to split and press "?" for an unsplit or a rejoin. Is there such a command?"
No, there is no un-split command. There are scripts that will unsplit but all they do is delete the right side event and extend the edge of the left event like you did.
~jr
Glenn Rotar
on Mar 31, 2014 at 12:05:16 am
Thanks for clearing that up. I appreciate that
