Imported .mp4 pixelate in Vegas and remain pixelated after rendering
COW Forums : VEGAS Pro
<< PREVIOUS   •   VIEW ALL   •   PRINT
Rebecca Siempre
on May 20, 2014 at 4:22:55 am
I have scoured countless forums to find an answer to my infuriating predicament. I have yet to find a question that details what I am experiencing, though I have tried numerous solutions given to people with problems of a similar nature, and they've never worked.
Before I import .mp4 files into Vegas they look crisp and perfect:
After I've imported them, the preview pixelates during movement:
And after rendering, the pixelation remains:
The example .mp4 specs:
General
Name: One Week Friends episode 2 [RAW].mp4
Folder: D:\Project Data\Anime\2014 Spring\One Week Friends
Type: Sony AVC
Size: 223.84 MB (229,213,399 bytes)
Created: Sunday, April 27, 2014, 5:56:04 PM
Modified: Sunday, May 18, 2014, 3:46:09 PM
Accessed: Sunday, May 18, 2014, 3:46:02 PM
Attributes: Archive
Vegas Movie Studio HD Platinum 10.0 specs:
Video
Template: Custom (1280x720, 59.940 fps)
Width: 1,280
Height: 720
Field order: None (progressive scan)
Pixel aspect ratio: 1.0000 (Square)
Frame rate: 59.940
Full-resolution rendering quality: Best
Deinterlace method: None
Audio
Master bus mode: Stereo
Sample rate (Hz): 44,100
Bit depth: 16
Resample and stretch quality: Good
Rendering specs:
Tempate: Internet 1280x720-30p
Video
Video format: AVC
Frame size: High definition (1280x720)
Profile: Baseline
Entropy coding: CAVLC
Frame rate: 29.970 (NTSC)
Field Order: Non (progressive scan)
Pixel aspect ration: 1.0000
Bit rate (bps): 8,000,000
Audio
Audio format: AAC
Sample rate (Hz): 48,000
Bit rate (bps): 128,000
Audio coding mode: Stereo
System
Format: MP4 file format (.mp4)
Project
Video rendering quality: (Use Project Settings)
I desperately need a solution to this! Cutting around the pixelation adds hours to my video editing time and forces me to use my second and third picks for shots.
Please and thank you!,
Becca
Mike Kujbida
Re: Imported .mp4 pixelate in Vegas and remain pixelated after rendering
on May 21, 2014 at 12:46:28 pm
You're going from a frame rate of 59.94 to 29.97 so your results don't surprise me.
Right click each event on your timeline, choose Properties and select Disable Resample.
Hopefully that will fix things for you. Good luck!!
Rebecca Siempre
on Jun 10, 2014 at 1:01:57 am
Just tried it. It didn't work. It behaves exactly the same.
