Rendering so slowly
COW Forums : VEGAS Pro
Dáithí Cinnsealach
Rendering so slowly
on Apr 28, 2016 at 1:08:38 pm
Okay, so I've just upgraded from Movie Maker. Rendering takes 3 hours for a 13 minute video. It's 1920x1080, 30 fps, set to best, using openCL. I also have it prioritised on cpu, as I thought that would help. It not a very powerful laptop I have, but should it be that slow? I had set it to good rendering yesterday, but didn't use the graphics card nor did I set the cpu usage to high in task manager. Any help?
John Rofrano
Re: Rendering so slowly
on Apr 29, 2016 at 11:25:18 pm
[Dáithí Cinnsealach] "set to best,"
Unless you are resizing the video, you can change Best to Good and get the SAME quality in HALF the time. There is a reason that Good is the default. You don't need to use Best unless you are resizing (e.g,., HD to SD) and it takes twice as long.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
