Encoding for DL.3 Mpg2 (format 2048x361)
COW Forums : Telestream Episode
Benno Klandt
on Mar 7, 2009 at 4:40:53 pm
I am trtying to encode prepared footage (animation codec 2048x361)for DL.3 Collager, and when resizing the format in episode to the dedicated size all I get is a white blank film, does someone knows the trick?
cheers
Benno
Robert Longwell
Re: Encoding for DL.3 Mpg2 (format 2048x361)
on Mar 10, 2009 at 4:01:53 pm
A solid white or colored screen like that usually means the codec is missing or unrecognized. Are you able to preview this file in Episode?
Robert Longwell
Thomas Giegerich
on Apr 5, 2009 at 12:05:11 am
Try giving Steve Mahanay at HES a call. He will be able to help you out with the perfect settings for those servers. Plus there is a tutorial on the HES homepage, that will guide you through the process.
What jumps to my eye when reading your post is the resolution that you are trying to convert. To my understanding MPEG2 will not let you encode odd pixel numbers. But that is just a guess - not sure on that one.
