AVIImporter: Unsupported Media Format
COW Forums : Telestream Episode
Harald Lapp
on May 15, 2008 at 9:27:09 pm
hello,
we have an issue with some AVIs which play in any video-player (including quicktime) just fine, but will crash episode with the following error message:
Thu May 15 18:39:27 2008 JOB 4221 ERROR 'configure components: unhandled excepti
on: "PW::CException" at component/importer/any/avi/AVIImporter.cpp:310; "Unsuppo
rted media format"'
the following file information is availabe with the tool 'mediainfo':
General #0
Complete name: /data/clips/incoming/21/00016dv4_3.avi
Format: AVI
Format/Info: Audio Video Interleave
Format/Family: RIFF
File size : 68.9 MiB
PlayTime : 20s
Bit rate : 29 Mbps
Video #0
Codec : Sony DV
Codec/Family : DV
Codec/Info : Sony Digital Video (DV) 525 lines at 29.97 Hz or 625 lines at 25.00 Hz
PlayTime : 20s
Width : 720 / 720 pixels
Height : 576 / 576 pixels
Display Aspect ratio : 4/3
Frame rate : 25.000 fps
Audio #0
Codec : Sony DV
Codec/Family : DV
Codec/Info : Sony Digital Video (DV), audio part
are there any known issues with this codec and episode engine?
thanks in advance,
harald
Craig Seeman
Re: AVIImporter: Unsupported Media Format
on May 15, 2008 at 9:46:55 pm
Is this a DV AVI? I just want to make sure I'm interpreting the info correctly. I've even used DV AVI in Final Cut Pro directly without issue.
It certainly is interesting that this would cause Episode to crash.
It is possible that there can be AVI conflicts in Quicktime and I wouldn't be surprised if such conflict might impact Episode.
I'll have to test a DV AVI on my end and see what happens.
What were you trying to compress it to?
