16x9 settings
COW Forums : Telestream Episode
Greg Mulvey
16x9 settings
on May 17, 2007 at 9:19:22 pm
I was surprised to see there were no templates for 16x9 settings in Epsisode Pro. This was a nice feature in Cleaner.
I know I can make my own custom settings, but I'm wondering if anyone knows if there are any online resources to download compression settings for Episode Pro?
Greg
Craig Seeman
Re: 16x9 settings
on May 17, 2007 at 11:39:41 pm
If you dig around there are a couple in there.
for SD Widescreen
DV/mov/NTSC Widescreen and PAL Widescreen
There's various HD presets
I've often wanted to create a set of presets for Episode but . . . (fill in excuse here).
I did make a preset specifically for DG/FastChannel (not 16:9).
It's easy enough to roll your own and save them though. It's often worthwhile to duplicate a preset and modify for a common purpose, for example, making a set to account for non square to square pixel encoding, change to Resize/Source display aspect ratio/Assume 4:3
Patrick Inhofer
Re: 16x9 settings
on May 21, 2007 at 6:36:27 pm
[Craig Seeman] "It's easy enough to roll your own and save them though. It's often worthwhile to duplicate a preset and modify for a common purpose, for example, making a set to account for non square to square pixel encoding, change to Resize/Source display aspect ratio/Assume 4:3"
I have client-specific folders with presets for their common requests. I usually make two versions of each one - 4:3 and 16:9.
Although it's a real pain when the app gets upgraded. I usually have to spend a half-day re-doing them.
FYI - It's actually very easy to tell the app to make 16:9. A total of about 2 pulldowns, I think... though it took me months to figure that out.
- pi
Patrick Inhofer
Finisher-in-Chief
Fini, nyc
Patrick Inhofer
Re: 16x9 settings
on May 25, 2007 at 1:38:28 am
[Patrick Inhofer] "I have client-specific folders with presets for their common requests. I usually make two versions of each one - 4:3 and 16:9."
It seems this doesn't work as well as I'd originally thought.
I can't get Episode to remember my Custom frame size, Aspect Ratio settings...
I guess this is another one for the Wish List.
- pi
Patrick Inhofer
Finisher-in-Chief
Fini, nyc
Robert Longwell
Re: 16x9 settings
on May 25, 2007 at 2:33:34 am
It doesn't 'remember' your settings??? Silly question, but you are saving your settings right? I've never had a profile simply lose any of my settings.
Robert Longwell
klouden
Re: 16x9 settings
on May 25, 2007 at 2:18:34 pm
Robert is correct, you must save your settngs for them the persist.
Another tip, if you add a setting to the batch window and make changes to it in the batch window (by double clicking on it), those changes do not follow back to the original settting in the browser (the original in the left had column). The setting in the batch window is a "copy" of the original in the browser. This was designed so that you could make a basic setting, then make individual changes to it as needed for the file being transcoded, without altering the original "basic" setting.
If you want to save off the changes you made to the batch window setting, you can save that as another preset.
Now if you are editing a setting in the settings editor window, you are altering the original, and you have to save it to take any changes.
Kevin Louden
Application Specialist | Mac Products
http://www.telestream.net | http://www.flip4mac.com
Patrick Inhofer
Re: 16x9 settings
on May 25, 2007 at 2:31:31 pm
[klouden] "Robert is correct, you must save your settngs for them the persist."
Okay.
Which of you crawled into my machine yesterday and fixed this????
Seriously, nothing you've guys said is news to me. I've been using this software since Compression Master first shipped and I've figured out all the various quirks in regards to saving presets.
Yet yesterday, when applying 16:9 presets that I had built about 3 weeks ago they didn't come across when applied.
This morning I rebuilt the presets and all is well in Metropolis.
Thanks guys.
- patrick
Patrick Inhofer
Finisher-in-Chief
Fini, nyc
Craig Seeman
Re: 16x9 settings
on May 25, 2007 at 2:33:49 pm
Related to the above It's possible to become confused over which setting you're editing, the original in the left hand column or the copy attached to the clip in the Job Batch.
Clicking on the left hand column setting (Compression Settings window), you'll see an "Open Settings:" at the top which will point to where your template is stored.
If you open a setting attached to the Job Batch a window will slide down. There's no path shown at the top and you'll see Preview, Cancel, Apply along the bottom.
If you change a setting in the Job Batch you'll see two icons appear under the Action column in the Job Batch, one is Save As and the other is Restore. Save As will allow you to save your modified setting wherever you'd like for future use.
