clientserver crashing
COW Forums : Telestream Episode
Conrad Olson
on Apr 24, 2008 at 10:13:03 am
Hi guys,
I'm struggling to get a particular encode to work. I have a full HD clip 1920x1080 25p as an animation QuickTime and I'm trying to encode it into a 29.97 H264 clip. I've switched on the PAL > NTSC settings in the frame rate options.
The clip is less than 2 mins long but I've not been able to get through the encode without it failing. I was running it on my machine to start with and it just failed with "Unhandled Exception" listed in the Job Batch list. It thought it might have been a RAM issue because I was rendering After Effects stuff at the same time so I opened Episode on one of the other Macs (pretty much identical). This time it keeps failing but with a clientserver crash being flagged by OSX. Each time it crashes after a different length of time.
Both machine are 8-core MacPros running 10.5.2 (with all the Software Updates) with 6GB RAM.
The settings I'm using are a preset I made last week, which worked fine, until I switch on the frame rate options. I just set a WMV encode off on the other machine and it worked fine.
Any suggestions?
Robert Longwell
Re: clientserver crashing
on Apr 24, 2008 at 1:47:23 pm
Every now and then, some settings are not compatible with the others. So *maybe* the 25->29.97 frame rate change was just enough to throw the software into a tail spin. It is rare, but it does happen.
I'd suggest doing this encode in 2 steps as a work around:
!) First do an encode to uncompressed MOV format, and do the sizing and frame rate change.
2) Take this new file and convert to H264.
Again, this is a work around but should do the trick.
Robert Longwell
Conrad Olson
on Apr 24, 2008 at 1:55:27 pm
Thanks for the suggestion. I'll give that a go and let you know what happens.
Seeing as I can't encode to the Animation codec (see previous post) with Pro should I encode to None or Video to get an uncompressed QuickTime?
Craig Seeman
on Apr 24, 2008 at 2:30:02 pm
Do you know how to read a crash log from the Console? Can you tell me what the first line is after "Thread 0"
Conrad Olson
on Apr 24, 2008 at 2:47:43 pm
OK, so I've opened the Console from Utilities, selected Log FIles from the side and gone into Crash Reported and I've got a list of clientserver logs:
The first line after Thread 0 says:
0 libSystem.B.dylib 0x92410a22 semaphore_wait_trap + 10
Hope that helps. Let me know if you need anything else.
Craig Seeman
on Apr 24, 2008 at 4:10:11 pm
Absolutely helps. I've seen this happen too. I have some hunches. If you can get me your email address ASAP, I'll send you FTP info so you can upload the source file and settings if you'd be willing. I'd love to test this.
Conrad Olson
on Apr 24, 2008 at 4:17:05 pm
My address is conrad"dot"olson"at"hmxmedia"dot"com
Craig Seeman
on Apr 24, 2008 at 4:25:33 pm
Sent you email with FTP info. I've bumped into this too and I've contacted Telestream about it.
Harald Lapp
on Apr 25, 2008 at 6:28:27 am
hello,
we are very new to episode (just purchased the license some weeks ago), and we have the same or a similar problem with some clips of a customer. the crash report however tells me the following:
Thread 0:
0 libSystem.B.dylib 0x94423b06 mach_wait_until + 10
we are running episode engine pro 4.4.2 on an osx server 10.5.2
maybe you could keep the thread up to date with any news on this topic?
thanks,
harald
Craig Seeman
on Apr 25, 2008 at 3:14:30 pm
While the crash thread looks slightly different it still indicates what I think is some sort of "time out" issue.
Can you post your full system specs and software versions involved? Would you be willing to send me a clip if I sent you FTP info. I am forwarding the results of my tests to the folks at Telestream.
Conrad Olson
on May 1, 2008 at 4:31:51 pm
Hi Craig,
I'm sorry I couldn't upload any footage last week but were you able to recreate the issue? I've just had the same problem with a different Animation QuickTime, using different compression settings, but still going to WMV. The console said
0 libSystem.B.dylib 0x9164da22 semaphore_wait_trap + 10
Any ideas?
Craig Seeman
on May 1, 2008 at 4:48:43 pm
I'm finding that what one is encoding to and the settings may be a factor. In other words, although the same crash is exhibited, there may be different correlates.
If you're going to WMV what frame rate is your setting?
Try 29.97 or 30 (if you're in NTSC land) or 25 if you're in PAL land.
Conrad Olson
on May 1, 2008 at 5:22:03 pm
We're in PAL land. Last time I was trying to do a frame rate conversion from 25p to 29.97. This time I'm working from a 24p clip, just keeping it 24p.
Craig Seeman
on May 1, 2008 at 5:40:30 pm
Can you post full specs on your source clip and a bit about your WMV settings? I'll see if I can duplicate on my end. All my 24p (23.98) source is 720p so if it's an Standard Def file, would you be able to get me the file?
I bumped into an this issue myself with a 29.97fps source file in which WMV settings was 15fps. Changed the WMV setting to 29.97 and it encoded every time. At FPS I got clientserver crash every time.
I'm curious to see if there's some sort of issue with certain sources and certain WMV frame rate settings.
Harald Lapp
on May 6, 2008 at 2:44:46 pm
sorry, i ran out of time last weeks. many thanx for your offer. i would be more than happy if i could upload you a file.
Harald Lapp
on May 15, 2008 at 9:17:28 pm
we managed to solve the problem by taking a setting which came with episode and adjusting the values to our needs. this worked just fine and so the problem is solved for us.
Craig Seeman
on May 15, 2008 at 9:42:09 pm
What source file type and what setting?
It might be a good to know for those of us who might bump into this issue.
Of course maybe Telestream can fix it too.
Conrad Olson
on Jun 12, 2008 at 6:29:09 pm
I've just experienced another clientserver crash, this time trying to encode H.264 from an HD source. The one thing different about this clip is that it's 60fps. Ended up having to use Compressor instead. Is this a different issue? Here is the log:
Process: clientserver [10816]
Path: /Applications/Episode.app/Contents/Resources/cm/bin/clientserver
Identifier: clientserver
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: Episode [10392]
Date/Time: 2008-06-12 18:45:10.364 +0100
OS Version: Mac OS X 10.5.3 (9D34)
Report Version: 6
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: 16
Thread 0:
0 libSystem.B.dylib 0x9461c4e2 semaphore_wait_trap + 10
1 libSystem.B.dylib 0x94694635 pthread_join + 706
2 libsys.dylib 0x0006b660 PW::CM::Sys::RComponentChainItem::join() + 32
3 clientserver 0x00004709 ClientServer::parseJob(PW::CM::Sys::CMD&, char*) + 5385
4 clientserver 0x00002e28 ClientServer::main(int, char**) + 994
5 clientserver 0x0000277a main + 76
6 clientserver 0x00002712 start + 258
7 clientserver 0x00002639 start + 41
Thread 1:
0 libSystem.B.dylib 0x9461c4ee semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x9464e866 _pthread_cond_wait + 1267
2 libSystem.B.dylib 0x94694371 pthread_cond_wait + 48
3 com.apple.AppleProRes422 0x110f332d 0x110d1000 + 140077
4 libSystem.B.dylib 0x9464d6f5 _pthread_start + 321
5 libSystem.B.dylib 0x9464d5b2 thread_start + 34
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
0 libpwcore.dylib 0x00173b6a __intel_new_memcpy + 2234
Thread 12:
Thread 13:
3 libcm.dylib 0x000d7d48 __ZN2PW2CM13RQFrameReader8nextNodeEv. + 84
4 pw_filter_any_statistics.so 0x001bedb6 non-virtual thunk to FrameCounter::runloop(pwbase::object_refcount*) + 26
5 libSystem.B.dylib 0x9464d6f5 _pthread_start + 321
6 libSystem.B.dylib 0x9464d5b2 thread_start + 34
Thread 14:
4 pw_exporter_any_mov.so 0x006f6246 non-virtual thunk to MOVExporter::runloop(pwbase::object_refcount*) + 26
Thread 15:
0 libpwcore.dylib 0x00173b79 __intel_new_memcpy + 2249
1 libcm.dylib 0x000d11f4 __ZN2PW2CM6RFrameC9EPKS1_jjPhNS_17ConstructionFlagsE + 514
2 libcm.dylib 0x000d2065 __ZN2PW2CM11RVideoFrameC9EPKS1_jjPhjNS_17ConstructionFlagsE + 57
3 pw_decoder_video_qt.so 0x00719fc6 QTVideoDecoder::try_to_put_frame(QTVideoDecoder*, PW::RPtr, char*, int, int, unsigned int, unsigned int, float) + 236
4 pw_decoder_video_qt.so 0x00719df4 QTVideoDecoder::frameDecodedQTCallback(void*, long, unsigned long, __CVBuffer*, long long, long long, unsigned long, void*, void*) + 400
5 com.apple.QuickTime 0x9599cb81 icmCallDecompressionTrackingCallback + 1213
6 com.apple.QuickTime 0x95a017aa decompressionSessionCompletionProc + 92
7 com.apple.QuickTime 0x9599c362 CommonAsyncProc + 426
8 com.apple.QuickTime 0x9599da3e ICMDecompressCompleteWithBuffer + 152
9 ...ickTimeComponents.component 0x948c635e BaseCodec_FinishFrame + 625
10 ...ickTimeComponents.component 0x948c87d3 BaseCodec_DrawBandComplete + 295
11 ...ickTimeComponents.component 0x948c894d BaseCodec_DecompressWorkFunction + 81
12 ...ickTimeComponents.component 0x948c6b94 BaseCodec_DecompressCallBack_Common + 1300
13 ...ickTimeComponents.component 0x948c9dea Base_CDBandDecompress + 3725
14 ...ickTimeComponents.component 0x948c517b Base_CDComponentDispatch + 125
15 com.apple.AppleProRes422 0x110d4b74 IcpDecompressorComponentDispatch + 96
16 ...ple.CoreServices.CarbonCore 0x907daf31 CallComponentDispatch + 29
17 com.apple.QuickTime 0x9599b2d3 ImageCodecBandDecompress + 43
18 com.apple.QuickTime 0x959855bf DoBandedDecompress + 15472
19 com.apple.QuickTime 0x9598154a ICMAction + 650
20 com.apple.QuickTime 0x9598020a ICMDeviceLoop + 557
21 com.apple.QuickTime 0x9598ac8a DecompressSequenceFrameWhen + 843
22 com.apple.QuickTime 0x9598a60f ICMDecompressionSessionDecodeFrame + 671
23 pw_decoder_video_qt.so 0x00719a49 QTVideoDecoder::decode_frame(PW::RPtr) + 171
24 pw_decoder_video_qt.so 0x007196ce QTVideoDecoder::process() + 1008
25 libcm.dylib 0x000d54ac __ZN2PW2CM24CMMultipleQueueComponent7runloopEPN6pwbase15object_refcountE. + 28
26 libSystem.B.dylib 0x9464d6f5 _pthread_start + 321
27 libSystem.B.dylib 0x9464d5b2 thread_start + 34
Thread 16 Crashed:
0 libSystem.B.dylib 0x946fddbe __semwait_signal_nocancel + 10
1 libSystem.B.dylib 0x946efc87 usleep$NOCANCEL$UNIX2003 + 61
2 libSystem.B.dylib 0x9471148b abort + 85
3 libcm.dylib 0x000d489a PW::CM::RComponent::handleNotifications() + 0
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 16 crashed with X86 Thread State (32-bit):
eax: 0x0000003c ebx: 0x946fd90f ecx: 0xb083ed9c edx: 0x946fddbe
edi: 0x000d546e esi: 0xb083edf8 ebp: 0xb083edd8 esp: 0xb083ed9c
ss: 0x0000001f efl: 0x00000247 eip: 0x946fddbe cs: 0x00000007
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0xb0943c58
Binary Images:
0x1000 - 0xdfe5 +clientserver ??? (???) /Applications/Episode.app/Contents/Resources/cm/bin/clientserver
0x1f000 - 0x32feb +libpw.dylib ??? (???) <3076501e91074452bc000574efb940fd> /Applications/Episode.app/Contents/Resources/cm/lib/libpw.dylib
0x42000 - 0x42ffd libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib
0x66000 - 0xb0fe7 +libsys.dylib ??? (???) <0063e879ed6e44ed89978471d5a682a8> /Applications/Episode.app/Contents/Resources/cm/lib/libsys.dylib
0xcc000 - 0x125fc7 +libcm.dylib ??? (???) <0b10df93e6e64d0e8cfdf57777fa5672> /Applications/Episode.app/Contents/Resources/cm/lib/libcm.dylib
0x154000 - 0x18aff3 +libpwcore.dylib ??? (???) /Applications/Episode.app/Contents/Resources/cm/lib/libpwcore.dylib
0x1ad000 - 0x1b7fef +pw_importer_any_mov.so ??? (???) <119023d947784fc2901b36075987f223> /Applications/Episode.app/Contents/Resources/cm/component/pw.importer.any.mov/darwin/x86/pw_importer_any_mov.so
0x1bd000 - 0x1c0ffb +pw_filter_any_statistics.so ??? (???) /Applications/Episode.app/Contents/Resources/cm/component/pw.filter.any.statistics/darwin/x86/pw_filter_any_statistics.so
0x1c5000 - 0x1c9fc7 +pw_encoder_video_qt.so ??? (???) /Applications/Episode.app/Contents/Resources/cm/component/pw.encoder.video.qt/darwin/x86/pw_encoder_video_qt.so
0x400000 - 0x46cffd +libqt.dylib ??? (???) <732e1413add344dc8e7887dab5e82c93> /Applications/Episode.app/Contents/Resources/cm/lib/libqt.dylib
0x4a7000 - 0x63900d +pw_filter_video_resize.so ??? (???) <7182d1843aae4f4e8bb5aabdff779d98> /Applications/Episode.app/Contents/Resources/cm/component/pw.filter.video.resize/darwin/x86/pw_filter_video_resize.so
0x6f5000 - 0x70cff3 +pw_exporter_any_mov.so ??? (???) /Applications/Episode.app/Contents/Resources/cm/component/pw.exporter.any.mov/darwin/x86/pw_exporter_any_mov.so
0x716000 - 0x71dfef +pw_decoder_video_qt.so ??? (???) <475bc38b3873427aa51f4af16fc4208f> /Applications/Episode.app/Contents/Resources/cm/component/pw.decoder.video.qt/darwin/x86/pw_decoder_video_qt.so
0x7aa000 - 0x7adfef com.apple.LiveType.component 2.1.3 (2.1.3) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x7b2000 - 0x7f8fc3 com.apple.motion.component 1.0 (1.0) <77973a134e79426f853f2318e52a2207> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x11000000 - 0x11065fde com.apple.LiveType.framework 2.1.3 (2.1.3) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0x11085000 - 0x1108802f +Motion ??? (???) /Library/Frameworks/Motion.framework/Versions/A/Motion
0x1108d000 - 0x110aeff1 +pw_converter_any_converterlib.so ??? (???) /Applications/Episode.app/Contents/Resources/cm/component/pw.converter.any.converterlib/darwin/x86/pw_converter_any_converterlib.so
0x110d1000 - 0x1110bfff com.apple.AppleProRes422 1.0.2 (46) /Library/QuickTime/AppleProRes422.component/Contents/MacOS/AppleProRes422
0x11157000 - 0x11169fd9 com.apple.FCP Uncompressed 422.component 1.5 (1.5) /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
0x1659c000 - 0x165d7fff com.apple.QuickTimeFireWireDV.component 7.4.5 (67) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x165e6000 - 0x16600fe3 com.apple.AppleIntermediateCodec 1.2 (145) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0x16605000 - 0x1660affb com.apple.AppleMPEG2Codec 1.0 (211) /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
0x16c25000 - 0x16c61fe3 com.apple.AppleVAFramework 4.0.20 (4.0.20) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x16e48000 - 0x16e62fe3 com.apple.applepixletvideo 1.2.16 (1.2d16) <798930d46fb63202d054bbabf6e8c0e6> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x16f13000 - 0x17138ffc +org.perian.Perian 1.1 (1.1) <1f0d751abac46ab4fe8b505bbdd89219> /Library/QuickTime/Perian.component/Contents/MacOS/Perian
0x17215000 - 0x17455fd2 +net.telestream.wmv.import 2.2.0.49 (2.2.0.49) /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
0x1748d000 - 0x175e9fdf +com.red.redcode.quicktime 1.5 (1.5) /Library/QuickTime/REDCODE.QT.component/Contents/MacOS/REDCODE.QT
0x1768a000 - 0x1784cfea +net.telestream.wmv.advanced 2.2.0.49 (2.2.0.49) /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
0x17890000 - 0x178d4fe7 com.apple.DVCPROHDCodec 1.4 (231) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
0x178e9000 - 0x1798cffe com.apple.AppleHDVCodec 1.4 (218) <5850ee1a6a354baf81929f784647da01> /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
0x179aa000 - 0x179caff3 com.apple.IMXCodec 1.3.1 (147) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
0x8fe00000 - 0x8fe2da53 dyld 96.2 (???) <7af47d3b00b2268947563c7fa8c59a07> /usr/lib/dyld
0x90003000 - 0x90003ff8 com.apple.Cocoa 6.5 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x90004000 - 0x90033fe3 com.apple.AE 402.2 (402.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x90051000 - 0x9011cfff com.apple.ColorSync 4.5.0 (4.5.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9011d000 - 0x901c4feb com.apple.QD 3.11.52 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x901c5000 - 0x90392fe7 com.apple.security 5.0.3 (33532) <3bef414f3c6f433e707ac5abee340e16> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x90393000 - 0x903a3fff com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <06d8fc0307314f8ffc16f206ad3dbf44> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x903a4000 - 0x903d3ff7 libncurses.5.4.dylib ??? (???) <3b2ac2ca8190942b6b81d2a7012ea859> /usr/lib/libncurses.5.4.dylib
0x903fd000 - 0x90443fef com.apple.Metadata 10.5.2 (398.18) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x90449000 - 0x9046dfff libxslt.1.dylib ??? (???) <4933ddc7f6618743197aadc85b33b5ab> /usr/lib/libxslt.1.dylib
0x9046e000 - 0x9046effb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x905ab000 - 0x905e9ff7 libGLImage.dylib ??? (???) <093b1b698ca93a0380f5fa262459ea28> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x905ed000 - 0x905f2fff com.apple.CommonPanels 1.2.4 (85) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x905f3000 - 0x9060bfff com.apple.openscripting 1.2.6 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x90618000 - 0x906fdff3 com.apple.CoreData 100.1 (186) <8e28162ef2288692615b52acc01f8b54> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x906fe000 - 0x90758ff7 com.apple.CoreText 2.0.2 (???) <9fde11f84a72e890bbf2aa8b0b13b79a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90759000 - 0x9079bfef com.apple.NavigationServices 3.5.2 (163) <91844980804067b07a0b6124310d3f31> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9079c000 - 0x907a6feb com.apple.audio.SoundManager 3.9.2 (3.9.2) <0f2ba6e891d3761212cf5a5e6134d683> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x907a8000 - 0x90a82ff3 com.apple.CoreServices.CarbonCore 786.4 (786.4) <059c4803a7a95e3c1a95a332baeb1edf> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90a83000 - 0x90ab0feb libvDSP.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x90ab7000 - 0x90b33feb com.apple.audio.CoreAudio 3.1.0 (3.1) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x90b34000 - 0x90baeff8 com.apple.print.framework.PrintCore 5.5.3 (245.3) <222dade7b33b99708b8c09d1303f93fc> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x90baf000 - 0x90bb5fff com.apple.print.framework.Print 218.0.2 (220.1) <8bf7ef71216376d12fcd5ec17e43742c> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x90bb6000 - 0x90f74fea libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x90f75000 - 0x9103cff2 com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91082000 - 0x91083ffc libffi.dylib ??? (???) /usr/lib/libffi.dylib
0x91084000 - 0x91494fef libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x914ca000 - 0x9157afff edu.mit.Kerberos 6.0.12 (6.0.12) <1dc515ebe407292db8e603938c72d4e8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9157c000 - 0x91606fe3 com.apple.DesktopServices 1.4.6 (1.4.6) <94d1a28b351b7dff77becadab0967772> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x91607000 - 0x91607fff com.apple.Carbon 136 (136) <450e7e239de3f8e559c78f6473ec5149> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x91c98000 - 0x91cb8ff2 libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x91cb9000 - 0x91df1ff7 libicucore.A.dylib ??? (???) <5031226ea28b371d8dfdbb32acfb48b5> /usr/lib/libicucore.A.dylib
0x91df2000 - 0x91df6fff libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x91f1e000 - 0x91f2afe7 com.apple.opengl 1.5.6 (1.5.6) <125de77ea2434a91364e79a0905a7771> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x91f2b000 - 0x91f2bff8 com.apple.ApplicationServices 34 (34) <8f910fa65f01d401ad8d04cc933cf887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x91f2c000 - 0x91f2cffa com.apple.CoreServices 32 (32) <2fcc8f3bd5bbfc000b476cad8e6a3dd2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x91f2d000 - 0x91f4cffa libJPEG.dylib ??? (???) <0dd7e9d7fb22174b78205a944144f9c3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91f4d000 - 0x91f75fff libcups.2.dylib ??? (???) /usr/lib/libcups.2.dylib
0x91fc7000 - 0x9205afff com.apple.ink.framework 101.3 (86) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x9205b000 - 0x920abff7 com.apple.HIServices 1.7.0 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x920ac000 - 0x920b3ffe libbsm.dylib ??? (???) /usr/lib/libbsm.dylib
0x920b4000 - 0x92195ff7 libxml2.2.dylib ??? (???) <1baef3d4972ee789d8fa6c1fa44da45c> /usr/lib/libxml2.2.dylib
0x92196000 - 0x921cdfff com.apple.SystemConfiguration 1.9.2 (1.9.2) <8b26ebf26a009a098484f1ed01ec499c> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9221e000 - 0x92249fe7 libauto.dylib ??? (???) <42d8422dc23a18071869fdf7b5d8fab5> /usr/lib/libauto.dylib
0x922d7000 - 0x92973fff com.apple.CoreGraphics 1.351.31 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x92974000 - 0x92977fff com.apple.help 1.1 (36) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x92978000 - 0x92980fff com.apple.DiskArbitration 2.2.1 (2.2.1) <75b0c8d8940a8a27816961dddcac8e0f> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x929b2000 - 0x92d48fff com.apple.QuartzCore 1.5.3 (1.5.3) <1b65c05f89e81a499302fd63295b242d> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x92d49000 - 0x93546fef com.apple.AppKit 6.5.3 (949.33) <84b236f43802f4c15011513d18efa101> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x93547000 - 0x93626fff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0x93627000 - 0x93642ff3 libPng.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x93643000 - 0x936cefff com.apple.framework.IOKit 1.5.1 (???) <60cfc4b175c4ef60bb8e9036716a29f4> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x93938000 - 0x93e0bffe libGLProgrammability.dylib ??? (???) <475db64244e011cd8811e076035b2632> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x93e7f000 - 0x93e88fff com.apple.speech.recognition.framework 3.7.24 (3.7.24) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x93f11000 - 0x93f6aff7 libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x93f83000 - 0x94056fef com.apple.QuickTimeH264.component 7.4.5 (67) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x94209000 - 0x9421dff3 com.apple.ImageCapture 4.0 (5.0.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x9421e000 - 0x9422cffd libz.1.dylib ??? (???) <5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
0x94410000 - 0x9444afff com.apple.coreui 1.1 (61) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9444b000 - 0x9444bffd com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9444c000 - 0x944d3ff7 libsqlite3.0.dylib ??? (???) <6978bbcca4277d6ae9f042beff643f7d> /usr/lib/libsqlite3.0.dylib
0x944d4000 - 0x9461aff7 com.apple.ImageIO.framework 2.0.2 (2.0.2) <77dfee73f4c0d230425a5151ee0bce05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9461b000 - 0x9477bff3 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
0x9477c000 - 0x9582cff6 com.apple.QuickTimeComponents.component 7.4.5 (67) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x9582d000 - 0x9582dffc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x95895000 - 0x95895ffd com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x95896000 - 0x95898ff5 libRadiance.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x95899000 - 0x95bb9fe2 com.apple.QuickTime 7.4.5 (67) <520cbf4ae05622466ad1b89f1ba3a4e1> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x95bba000 - 0x95bc1fff com.apple.agl 3.0.9 (AGL-3.0.9) <7dac4a7cb0de2f6d08ae71c1249379e3> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x95d4f000 - 0x95e01ffb libcrypto.0.9.7.dylib ??? (???) <330b0e48e67faffc8c22dfc069ca7a47> /usr/lib/libcrypto.0.9.7.dylib
0x95e21000 - 0x95e21ffd com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x95e22000 - 0x95e29fe9 libgcc_s.1.dylib ??? (???) /usr/lib/libgcc_s.1.dylib
0x95e3c000 - 0x95f30ff4 libiconv.2.dylib ??? (???) /usr/lib/libiconv.2.dylib
0x95f31000 - 0x95f70fef libTIFF.dylib ??? (???) <76301b3506f310fb454b58897c8d0a9f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x96169000 - 0x96470ff7 com.apple.HIToolbox 1.5.3 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x964ab000 - 0x96528fef libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x96560000 - 0x967dbfe7 com.apple.Foundation 6.5.5 (677.19) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x96919000 - 0x969acff3 com.apple.ApplicationServices.ATS 3.3 (???) <064eb6d96417afa38a80b1735c4113aa> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x969ad000 - 0x969cbfff libresolv.9.dylib ??? (???) <0629b6dcd71f4aac6a891cbe26253e85> /usr/lib/libresolv.9.dylib
0x969d4000 - 0x969d8fff libGIF.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x96a03000 - 0x96b27fe3 com.apple.audio.toolbox.AudioToolbox 1.5.1 (1.5.1) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x96b28000 - 0x96baaffb com.apple.CFNetwork 330 (330) <6c5eda16e640b09334809ba4c1df985d> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x96d08000 - 0x96e3afff com.apple.CoreFoundation 6.5.2 (476.13) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x96e3b000 - 0x96e98ffb libstdc++.6.dylib ??? (???) <04b812dcec670daa8b7d2852ab14be60> /usr/lib/libstdc++.6.dylib
0x96e99000 - 0x96eaffe7 com.apple.CoreVideo 1.5.0 (1.5.0) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x96eb0000 - 0x96ec6fff com.apple.DictionaryServices 1.0.0 (1.0.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x96ed4000 - 0x96ee4ffc com.apple.LangAnalysis 1.6.4 (1.6.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x96ee5000 - 0x96f71ff7 com.apple.LaunchServices 289.2 (289.2) <3577886e3a6d56ee3949850c4fde76c9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x96f72000 - 0x96f74fff com.apple.securityhi 3.0 (30817) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9701e000 - 0x9707aff7 com.apple.htmlrendering 68 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x970f9000 - 0x97178ff5 com.apple.SearchKit 1.2.0 (1.2.0) <277b460da86bc222785159fe77e2e2ed> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x97179000 - 0x97233fe3 com.apple.CoreServices.OSServices 226.3 (226.3) <456bdd65b936baf1ef497b74b4f960a8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0xfffe8000 - 0xfffebfff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
jay ingles
on Jun 4, 2009 at 12:47:30 pm
Im experiencing this problem as well.
My source file was rendered out from FCP thru Export using Compressor with a PR HQ preset. Source footage is ApplePRHQ 720p in FCP. I'd then taken this file and exported with episode (latest version).
It crashes most of the time but worked sometime. The render should take 20-30 mins on my machine, but many times it says "less than a minute" then fails.
I've tried on both a new macbook pro & a 1.5year old 8core desktop.
any suggestions? very frustrating. Episode is very powerful but i find it very very finicky and fails with no explanation.
help anyone?
thanks.
jay
