WMV audio HELP!
COW Forums : Telestream Episode
Ming Saadprai
WMV audio HELP!
on Nov 22, 2007 at 3:48:30 am
Hi all, I'm in a bit of a fix and need some serious help! I'm trying to deliver a WMV with these settings;
Video: 300kbps, 320X240
Audio: 128kbps, 32khz, Mono, 16 bit
I've used Episode to make these audio settings by choosing a 128kbps,44.1khz, stereo, 16 bit and tweaked the channel and sample rate settings such that it becomes 32khz, mono. But when the WMV is encoded, it displays 128kbps,44.1khz, stereo, 16 bit in WMP, even though I've already tweaked it to the client's request.
I noticed with the Canopus Procoder, the audio presets are heavily defined as well - certain bitrates come defined with certain sample rates. Is there a way to make the WMV so it displays the actual audio settings? If not, how can I explain it to the client that there are heavily defined presets?
Am I making sense? Help!
Robert Longwell
Re: WMV audio HELP!
on Nov 23, 2007 at 3:13:48 pm
The WMV presets will likely override the sample rate and mono/stereo settings.
Robert Longwell
