New Features coming with Episode 6.5
COW Forums : Telestream Episode
Craig Seeman
on Apr 21, 2015 at 7:34:16 pm
elestream to Unveil Episode 6.5 at NAB
Now featuring support for new formats, closed captions, multi-bitrate encoding, and multi-track audio
Nevada City, Calif., April 7th, 2015 – Telestream®, the leading provider of digital video tools and workflow solutions today announced that it will unveil the latest version of its multiformat video encoding software Episode 6.5 at NAB 2015 on booth SL3305. Scheduled for release later in Q2 2015, version 6.5 will feature support for closed captions, new formats, multi-bitrate encoding, and multi-track audio.
Preserving the integrity of original content while transferring it between incompatible systems is a constant challenge for post-production professionals. Designed for the entire production workflow, Episode has the quality, filters, formats, and power to handle the entire process from camera to edit and all the way to final delivery. Episode produces “true to the original” results for simple transcoding jobs as well as for more complex encoding jobs such as standards conversion.
"With Episode 6.5, we concentrated on closed captioning support as well as adding the newer formats such as HEVC, VP9, and AS-11," said Barbara DeHart, Vice President of Desktop Business at Telestream. "Our continued goal is to give customers remarkable output quality in the most flexible and streamlined way possible. With versions starting just under $600, Episode is accessible anyone who is serious about video production."
New features in Episode 6.5 include:
Closed caption support
Episode 6.5 enables caption insertion with encoding and pass-through options, and supports CEA-608 and CEA-708 captioning standards as well as MCC and SCC caption formats. With federal regulations mandating captioning, this will enable postproduction workflows to handle embedded captions easily.
Support for virtually any video and audio file format
Episode supports the widest range of formats in its class, allowing users to repurpose media for websites, mobile devices, television, archive, disk authoring and more. With version 6.5, Episode adds support for formats including HEVC, XAVC, VP9, and MXF AS-11.
Multi-bitrate streaming support
Multi-bitrate streaming improves a viewer's experience by letting users deliver videos in the resolution and bit rate that best matches viewers’ connection speeds. With version 6.5, users will be able to easily encode and create packages for Apple HLS (HTTP Live Streaming), Microsoft Smooth Streaming, and MPEG-DASH with a click of a button.
Support for multi-track audio
Featuring improved performance and stability, Episode 6.5 adds presets and filters to easily map multi-track audio channels -- rearrange audio tracks, change speaker assignments, and change audio formats and sample rates.
Image sequence support
Image sequences are now available directly from the Episode UI, which provides an easy way to manage thousands of frames for 3D animation and compositing for visual effects. Users can step through the sequence frame by frame with the highest possible quality. It’s also possible to add multiple files from different sequences for multiple encode tasks.
Available in three versions with incrementally increasing encoding speeds and format flexibility, Episode, Episode Pro, and Episode Engine are all supported on Mac and PC platforms. Because Episode’s transcode engine is completely multi-threaded, multiple jobs can be processed in parallel, utilizing all available power from modern multi-core workstations. Episode Pro enables two concurrent jobs, while Episode Engine supports an unlimited number of parallel jobs, across multiple machines.
When encoding speed is critical, Split-and-Stitch technology, available in Episode Engine, enables distributed and segmented encoding for any supported format, across multiple clustered Mac or PC workstations. Episode’s built-in file sharing system automatically offloads work from one machine to another without any user assistance. Whether sharing encodes between processing cores on a single workstation or across a cluster of cross-platform machines, Split-and-Stitch enables the fast encoding speeds possible.
More information is available at
Erik Lindahl
Re: New Features coming with Episode 6.5
on May 23, 2015 at 8:30:17 am
Nice they are finally updating this old beast. Sad their development cycle is so slow. I guess the competition for desktop-class encoders just isn't there and being virtually best in class in all areas even if you're a subpar program means you don't really have to innovate.
Craig Seeman
on May 25, 2015 at 6:50:54 pm
[Erik Lindahl] "Sad their development cycle is so slow."
I expect you'll see that changing.
[Erik Lindahl] "the competition for desktop-class encoders just isn't there"
I suspect that as Apple Compressor and Adobe Media Encoder improve, feature differentiation becomes more important for a professional third party encoder. That might indicate some development re-evaluation. Note the new features such as VP9, HEVC, MPEG DASH, MXF, Closed Captioning. improvements to Watch Folders including SSL mode for FTP and filter controls. It's important to have additional value features not found in the free/near free encoders.
Tim Halle
on Jul 9, 2015 at 5:56:11 pm
So I've installed E6.5 on a newer more powerful machine and am seeing no speed increase creating H264 MOVs. Been using your product for years so I know it pretty well and I have reviewed the best practices document. Whats up with this ? Any advice to get more speed ?
© 2018 All Rights Reserved
