Checking an MXF file with 8 channels of audio
COW Forums : Telestream Episode
Robert Haynes
on May 8, 2013 at 1:30:25 am
I made an MXF file with 8 channels of audio in episode. When I check the file in media info it says that it has 8 channels. When I play the file in VLC player I have to manually toggle through track 1, 2, 3 etc. It has all 8 and I've confirmed that they are what they should be (stereo + 5.1). I'm not very familiar with MXF files but when I check an MPEG-2 file it plays all of the audio channels at once which I output to a scope or monitor with audio levels to check them. Why is the MXF file only playing one track at a time? Is there a problem with the file or is that just how MXF works? Thanks for any help.
Also the specs said ODG Mezz SD MXF. I'm not sure what ODG means. Thanks if anyone can clue me in.
Episode Settings below:
Container: MXF Op1a (K2 server compliant op1a checked)(split audio channels to separate tracks checked)
Video Codec: MPEG-2
bit rate control CBR
bitrate 50,000
GOP format: IBBPBB
GOP Type: Closed
Profile: 422 (4:2:2)
Level: Main
detect scene changes checked
Audio Codec: AES
channel mapper: input 8; output 8; all channels mapped to themselves
sample rate: 48
bit depth: 24
Media info specs below:
Format : MXF
Format_Commercial_IfAny : XDCAM HD422
Format profile : OP-1a
Format settings : Closed / Complete
File size : 40.7 GiB
Duration : 1h 37mn
Overall bit rate : 59.9 Mbps
Encoded date : 2013-05-07 11:29:17.044
Writing application : OpenCube Technologies MXFTk Advanced 2.4.1.0.1
Writing library : OpenCube Technologies MXFTk Advanced 2.4.1.0.1
Video
Format : MPEG Video
Format version : Version 2
Format profile : 4:2:2@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format_Settings_Wrapping : Frame
Duration : 1h 37mn
Bit rate : 50.0 Mbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 4.823
Stream size : 34.0 GiB (83%)
Title : Picture
Audio #1
Format : PCM
Format settings, Endianness : Little
Format_Settings_Wrapping : Frame (AES)
Duration : 1h 37mn
Bit rate mode : Constant
Bit rate : 1 152 Kbps
Channel(s) : 1 channel
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Stream size : 802 MiB (2%)
Title : Sound
Audio #2
Format : PCM
Duration : 1h 37mn
Bit depth : 24 bits
Title : Sound
Audio #3
Format : PCM
Duration : 1h 37mn
Bit depth : 24 bits
Title : Sound
Audio #4
Format : PCM
Duration : 1h 37mn
Bit depth : 24 bits
Title : Sound
Audio #5
Format : PCM
Duration : 1h 37mn
Bit depth : 24 bits
Title : Sound
Audio #6
Format : PCM
Duration : 1h 37mn
Bit depth : 24 bits
Title : Sound
Audio #7
Format : PCM
Duration : 1h 37mn
Bit depth : 24 bits
Title : Sound
Audio #8
Format : PCM
Duration : 1h 37mn
Bit depth : 24 bits
Title : Sound
MinerWerks
Re: Checking an MXF file with 8 channels of audio
on May 23, 2013 at 5:52:44 pm
I use Sony's XDCAM Viewer (a small standalone player application) for tasks like this. It has checkboxes for each of the audio channels so you can turn them on and off to hear each output.
