Telestream Episode V6.4 Bunt in timecode problem
COW Forums : Telestream Episode
Neil Patience
on Apr 24, 2013 at 12:35:09 am
Hi
Hope someone can help. I have Episode V6.4 and wanted to create a burnt in timecode preset.
I have a simple 30 sec clip, Pal ProRes 1920x1080.
I set up an H264 conversion that resized to 1024x576 and added the burn timecode filter. No other filters used.
I just get a failed to configure components error in the status window. If I uncheck the burn timecode filter all encodes as it should.
I have tried it with a few different encoders, even keeping it ProRes and not resizing but returns same error.
Any thoughts as to what the problem is ?
(Episode V 6.4 running on a MBP 2.7Gig i7 with 16Gigs Ram OS 10.7.5)
Thanks in advance.
best wishes
Neil
http://www.patience.tv
8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
Craig Seeman
Re: Telestream Episode V6.4 Bunt in timecode problem
on May 6, 2013 at 9:37:57 pm
Are you still having this problem?
If so, let me know and I'll give you a hand.
Neil Patience
on May 6, 2013 at 11:14:15 pm
Hi Craig
Yes still happens - I gave up and use QT Change for BITC now but be nice to see if there is a solution
best wishes
Neil
