23.98 -> 29.97 Drop-Frame
COW Forums : Telestream Episode
Brian Foote
on Jul 5, 2012 at 3:23:08 pm
So im looking to go from 23.98 -> 29.97 Drop-Frame. I dont see Drop-Frame as an option anywhere, is this even possible to do?
My convert to 29.97 looks great, plays back flawlessly and sync is on point however, if I import into a Drop-Frame timeline it make my show 1:11 frames longer. At this point im scratching my head. If anyone has some insight i would appreciate it.
Thanks.
Brian Foote
Editorial | Motion Design
http://www.brianfoote.tv
John Heagy
Re: 23.98 -> 29.97 Drop-Frame
on Jul 14, 2012 at 2:12:16 am
Brian,
Sounds like you edited in 23.98 ND which is the only choice you have. The time you get will be longer than what your timeline indicates. You need to make your 23.98 timeline shorter so when you drop it into a DF timeline it's the correct time. Transcoding in ND or DF TC in Episode will have no effect on the actual duration.
John
