Converting .ts files to Quicktime or wmv in Episode
COW Forums : Telestream Episode
Benn Gunn
on Jun 21, 2012 at 4:51:04 pm
I have .ts files which I need to trim and convert to wmv and H.264 quicktime files using Episode
I notice that entering in and out points results in unusable files. However, I can convert to mpeg2 quite easily but the audio duration doubles up, leading to a double length video. If I use pass through it's fine.
I then cannot use the resulting mpeg2 file to cut or convert in any transcoder!
Any suggestions for how o do what I need to do and explainations for why what is happening happens?
Jessica Muth
Re: Converting .ts files to Quicktime or wmv in Episode
on Jun 21, 2012 at 4:54:08 pm
Not sure what it does that; could be Episode doesn't like Transport Streams. Try MPEG Streamclip instead.
http://www.squared5.com/
Jessica Muth
Production Operations Manager
Video Labs
Rockville, MD
301-217-0000
jmuth@videolabs.net
Benn Gunn
on Jun 26, 2012 at 10:50:59 am
Already tried it and it won't accept them.
I have noticed that if I run .ts to mpeg-PS with pass through audio it works, but the audio codec is still an issue. However, running that file through Episode again to mpeg-PS with mpeg2 audio results in a usable file which I can manipulate.
But surely there's a more direct route?
Bill Davis
on Jul 15, 2012 at 5:24:48 am
Sorry I didn't see this last month.
I'm pretty sure you can use DVDxDV to rip a clean DV stream out of .TS files. Which can then read into Episode.
Kinda clunky, but at least it will get you from point A to point B.
"Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions."-Justice O'Connor
