First use of V6
COW Forums : Telestream Episode
Mark Underkofler
First use of V6
on Dec 30, 2010 at 7:19:28 pm
Is it just me or do the output .mpg files seem extremely large? I'm sending a test :30 second spot to DG and it's 192megs going into Episode and 784megs coming out? Yeow!
I'm using an Apple ProRes 422 standard def file. This seems very inefficient... not to mention that uploading to DG becomes an hour long event.
Anybody have suggestions for a more efficient workflow to DG specs?
Craig Seeman
Re: First use of V6
on Jan 1, 2011 at 9:15:59 pm
Data rate and duration pretty define file size. With the correct settings the file size should be just under 100MB. Bit rate 18Mbps and a duration of 40 seconds with slate and black.
Mark Underkofler
Re: First use of V6
on Jan 2, 2011 at 9:37:18 pm
Craig,
That's pretty much what I figured. I used the DG Fastchannel setting from Telestream. Looks like data rate is 18Mps and duration is about 40 seconds.
Craig Seeman
Re: First use of V6
on Jan 2, 2011 at 10:15:34 pm
Using Episode 6.0.2 I just tested 720x486 40 second DG formatted master Apple ProResHQ source file which is 281.7MB
Using DG preset the resultant file is 92.6MB as shown in OS 10.6.5 Finder.
I use VideoSpec and get slightly smaller numbers for the file size (which might be binary vs dec calculation). Cross check your encoded file. Look at size in Finder and then check the same using VideoSpec.
Mark Underkofler
Re: First use of V6
on Jan 3, 2011 at 2:47:21 pm
Something squirrely is going on. Everything I encode with the DG_Patch settings results in a file exactly 781,931,111 bytes. And yes the file IS that big.
Dimensions 720x512
MPEG-2
WAAITTTT A MINUTE!!! Something's amiss in the duration. It shows 5:45.
HUMMMMMM.
Craig Seeman
Re: First use of V6
on Jan 3, 2011 at 3:32:52 pm
I'm using the DG_Patch setting. It's actually mine. I sent it to Telestream. It's rock solid for me and scores of others are using it so you need to look for some variable. I can't guess what it is with the info you've provided. Keep in mind I'm using Episode 6.0.2 as there was problems with the first iterations of 6.
Mark Underkofler
Re: First use of V6
on Jan 3, 2011 at 8:19:22 pm
I'm becoming a bit cheesed at Telestream. I spent $1000 on Episode 6 and can't get them to even open a support ticket. Is that extra? Perhaps for another $1000 I can get support.
I've put any number of files through and they all end up showing as humongous MPG 2 files almost 5 times the size of the original and all showing the same duration of 5:45.
This ain't brain surgery and I'd read the book if there was one... but what do you expect for a thousand bucks?
Reminds me of the Demotivator poster: "Customer Service... We're Not Happy Until You're Not Happy."
Craig Seeman
Re: First use of V6
on Jan 3, 2011 at 8:25:42 pm
In my experience if you fill out the support form on Telestream's site, they send you back an email response with a case number within 24 hours. Often that'll include what they're finding as well as requests for more information or files from you.
Mark Underkofler
Re: First use of V6
on Jan 4, 2011 at 2:54:18 pm
Craig,
I received stellar help from Linda at Telestream. She sent me a new DG patch that so far has worked in version 5. I haven't tried it in version 6 yet.
I'd love to know what the difference in the two patch files is???
Craig Seeman
Re: First use of V6
on Jan 4, 2011 at 5:02:59 pm
There's only one DG_Patch file I know of. Examine the two and see what settings are different. Perhaps you had a corrupted settings file.
Mark Underkofler
Re: First use of V6
on Jan 4, 2011 at 6:54:40 pm
Craig,
I opened the new DG Patch that was send by Telestream to me. It shows:
<?xml version="1.0"?>
<!DOCTYPE job SYSTEM "job.dtd">
<!--5.3-->
The version you sent me is:
<!--4.4.2-->
It is working.
Mark
Craig Seeman
Re: First use of V6
on Jan 4, 2011 at 7:28:06 pm
4.4.2 is a VERY OLD version. It doesn't take into account many new features. I may have sent that to you a very long time ago. The one Telestream sent you was also probably created by me as DG_Patch is my name for the preset.
