PAL DV to NTSC DV
COW Forums : Telestream Episode
Jim Cunningham
PAL DV to NTSC DV
on Dec 6, 2009 at 2:36:53 pm
I received PAL DVCam tapes. I digitized from Sony M25U PAL to FCS2. Everything to that point was fine. I dragged the PAL QT files into Episode 5.2. (MBP-10.4.11) Did short test, video/audio looked/sounded OK.
I did a 1 1/2 hour conversion, by the end of the segment the audio sync was off by about 8 seconds. I noticed that the Audio was set to 44.1K, changed that to 48K and tried again with the same out of sync audio.
Dragged the same piece into Compressor, PAL to NTSC conversion, it cam out fine.
Any thoughts as to a setting that I might have over looked in Episode?
Craig Seeman
Re: PAL DV to NTSC DV
on Dec 6, 2009 at 3:04:53 pm
Update to 5.3 and test again. Updates are bug fixes.
There also may be improvements to the standards conversions templates.
