source formats>>>SWF?
COW Forums : Telestream Episode
Joe Murray
on Jun 11, 2007 at 8:50:35 pm
Can Episode use a Flash video .swf file as the source file? I need to convert one to a Quicktime file, but the .swf file is unreadable by Episode.
Joe Murray
Robert Longwell
Re: source formats>>>SWF?
on Jun 12, 2007 at 11:44:43 am
No I do not believe so. Craig am I wrong?
Robert Longwell
Craig Seeman
on Jun 12, 2007 at 3:32:37 pm
Here a link to a PDF with Episode format support.
http://www.flip4mac.com/pdfs/EpisodeSeries_Format_Support.pdf
I haven't been able to use SWF as a source though. The above PDF implies that it should work if it's h.263 (Flash 7) or VP6 (Flash 8) on the "inside."
Joe Murray
on Jun 14, 2007 at 11:44:54 pm
Yes, I had read that list of supported formats, and it did seem to indicate that Episode could use .swf as a source file. This particular file can be opened and played in Quicktime.
Craig Seeman
on Jun 15, 2007 at 12:09:04 am
I'm going to do some investigating and see what's up with flash input support.
Magnus Hoem
on Jun 15, 2007 at 8:12:37 am
Yes, it should be able to do that. If you have a file containing audio and video that doesn't, please send a message to the episode support and they will take a look at what is wrong.
Craig Seeman
on Jun 18, 2007 at 6:54:34 pm
I sent examples of Flash7 and Flash8 SWF files that Episode 4.3.1 couldn't use as source. Magnus says they've found the issue and have a fix in the works.
