What for effect is that..?
COW Forums : Boris FX Particle Illusion
Rappel Master
on Apr 23, 2017 at 4:26:49 pm
hello...
I am looking for the following effect ...
This was created with particle illusion
Please help me...
Thx...
Rappel...
Francois Blawat
Re: What for effect is that..?
on May 9, 2017 at 9:07:49 pm
Rappel,
The only thing I can suggest is to use the "search" function that is part of the ParticleView program. Find something similar and then edit the effects to closely match what you are looking for. A lot of times, the Emitters under pi3 will not have an exact match as users will "tweak" an effect to match their needs. Using search I found something called StormTails located under emitters_04_06.il3 library that has the same sorta effect.
Good Luck.
FixitMad
Rappel Master
on Jul 2, 2017 at 12:25:42 am
Jou hey Francois...
Thank you for the info..!!
Will be there later to look ..
greeting Rappel...
