why is particle moving fast even velocity is set to 0?
COW Forums : Boris FX Particle Illusion
Pete Douglas
on Feb 4, 2017 at 4:09:49 am
Anybody could advice why is particle is still moving faster than a roller coaster when: velocity, spin bounce and everything is set to 0?
Francois Blawat
Re: why is particle moving fast even velocity is set to 0?
on Apr 15, 2017 at 2:42:17 am
Pete,
Try looking at this older Thread (Titled: Slowing down Particles) Located here: https://forums.creativecow.net/archivethread/23/497798#498149
It talks about decreasing something called the Force Strength if you are using a Force object.
I'm not sure that is what you were looking for, but this forum search function hopefully can also help you find your solution.
-Francois
FixitMad
