it is posible to eliminate trasparency for my own texture
COW Forums : Boris FX Particle Illusion
luis herzz
on Jul 11, 2016 at 11:25:44 pm
Hi everyone, im making a emitter with my oun texture, but i want it with 0 trasparency and it seems like it is imposible to removeit
Francois Blawat
Re: it is posible to eliminate trasparency for my own texture
on Jul 12, 2016 at 2:34:36 pm
[luis herzz]
I'm no expert, but try using an Image file that does not have transparency and see if that works. JPG or BMP perhaps. Can you try that to see if that works. You never mentioned what format your texture was saved in to begin with.
FixitMad
Francois Blawat
on Jul 12, 2016 at 9:37:08 pm
[luis herzz]
I just took a look at your image that you attached a bit closer this time. Try unchecking the Intense to see if that helps at all. You never mentioned what editor you used to create your image.
FixitMad
luis herzz
on Jul 13, 2016 at 4:18:35 pm
i was using png, with jpg works fine thx
