can't search particle View
COW Forums : Boris FX Particle Illusion
Leigh Young
on Jan 6, 2016 at 5:07:58 pm
I just bought and downloaded Particle Illusion 3 today and the particle View it came with won't search. I type something like "fire" into the search field but the SEARCH button deactivates and hitting return does nothing.
Brian Fox
Re: can't search particle View
on Jan 8, 2016 at 9:54:22 pm
Hi Leigh!
You should contact our support department at http://support.genarts.com/ to find out what's going on.
Brian
Leigh Young
on Jan 8, 2016 at 11:55:48 pm
I restarted Particle View and my computer and I can now search all the particles now. Luckily a simple fix that worked after a try or two.
Francois Blawat
on Jan 8, 2016 at 10:03:30 pm
Hi Leigh,
I'm sorry but I do not have a lot of experience with that particular issue. I would contact support@genarts.com to see if they can help you out especially since you just purchased Particle Illusion.
The only thing I can suggest until Alan or GenArts pops up here, is to make sure that once you Press S for search under ParticleView that you have both the IL3 and IEL/ELC boxes checked.
Good luck.
FixitMad
