particle Illusion is crashing ie version 10
COW Forums : Boris FX Particle Illusion
tony hampton
on Jul 30, 2015 at 10:55:12 am
hi
everytime i turn on the laptop and use ie it works fine
but then i turn on particle Illusion program it opens but then ie version 10 will stop
working is this happening to anyone else or just me ?
i when to genarts and didnt see any updates it was working fine with ie 8.1 i just may have
to use 8.1 of windows to have particle Illusion work again
thank you for your time
Francois Blawat
Re: particle Illusion is crashing ie version 10
on Aug 26, 2015 at 2:36:51 pm
I would e-mail support@genarts.com to get help since it appears that Alan does not frequent the forums as much as he used to.
Genarts should be able to assist you or at least tell you if there is a known issue that they are working on.
FixitMad
