A query regarding exporting of particle effects to images?
COW Forums : Boris FX Particle Illusion
David Bergstrom
on Oct 20, 2014 at 4:56:30 am
Hi everyone,
I have run into an issue when exporting a particle effect to a series of images. When I export the effect into the image set, the output is elongated vertically, and for the life of me I can't work out why. I'm assuming it's a setting somewhere, but I'm not sure what to change to fix it. My output SHOULD be 192x192 pixels, however the images are coming out at 320x240, which stretches the image rather badly. Does anyone know how I can try and fix this?
Any help would be greatly appreciated! :)
Regards,
David.
Alan Lorence
Re: A query regarding exporting of particle effects to images?
on Oct 20, 2014 at 12:40:10 pm
The pixel aspect information stored in the image files is wrong, so the viewer program you're using is stretching it -- at least that's what I think is happening.
Either set your viewer to ignore pixel aspect ratio (always use square pixels) or try saving in a different image format in pI.
Alan.
Alan Lorence
Product Manager
GenArts, Inc.
http://www.genarts.com
http://www.wondertouch.com
