PI won't output properly
COW Forums : Particle Illusion
Dan Cohen
on Nov 22, 2013 at 10:13:53 pm
Recently updated Particle Illusion, and now I can't output anything properly or at all. Output choices window comes up as normal, and then the 'save as' window, but regardless of the type of output I choose, it always wants to save it as an ip3 file. Got around it slightly by manually adding .mov extension, but this does not work in the same way when add a .png extension etc. Basically nothing happens at all, and I need to remove the background and output as a .png sequence. Bug fix?
Alan Lorence
Re: PI won't output properly
on Nov 22, 2013 at 11:08:05 pm
Use the Save Output (aka "render") button to create a movie or image sequence. The File - Save menu only saves the project file so you can load it later.
Alan.
Alan Lorence
Product Manager
GenArts, Inc.
http://www.genarts.com
http://www.wondertouch.com
Dan Cohen
on Nov 22, 2013 at 11:24:27 pm
Yes, that is what I did, problem as stated.
Alan Lorence
on Nov 25, 2013 at 3:26:32 pm
Email support at genarts dot com.
Alan.
Alan Lorence
Product Manager
GenArts, Inc.
Dan Cohen
on Nov 22, 2013 at 11:25:56 pm
Yes, that is what I did, problem as stated before.
