Background Blocking Particles
COW Forums : Particle Illusion
Michael Sutherland
on Sep 30, 2013 at 9:37:32 am
I am working on a short film with six layers: the background image and then five different layers of particle effects. Somehow I changed a setting--and I don't know which--that caused four of the layers to be blocked by the background. When I turn the background off, all five particle layers are visible. When I turn the background on, only one is visible. Every setting in the "Properties" sections of the layers and individual emitters are the same as before. I don't know what setting I changed. Does someone know how to fix this?
Terry Stephens
Re: Background Blocking Particles
on Sep 30, 2013 at 1:37:49 pm
It sounds to me like you may have accidently moved your background image above most of your other layers. I'm playing around with my new computer so I created a short video of what I think is wrong. If that is not the problem, You need Alan !
http://reels.creativecow.net/film/wheres-my-emmiters
Alan Lorence
on Sep 30, 2013 at 4:00:16 pm
I agree -- you probably dragged a layer upward in the layers window (upper left window). Drag it down to the bottom or r-click and "move down" until it's below everything.
Alan.
Alan Lorence
Product Manager
GenArts, Inc.
http://www.genarts.com
http://www.wondertouch.com
Michael Sutherland
on Oct 1, 2013 at 8:58:22 am
Yes, you're exactly right. I did as you suggested and the effects are back! I knew it had to be something simple. I just didn't know what it was.
